  • Legacy Donating Member
  • Member For: 17y 10m 2d
Posted
No worries..
Deadlifts, chins(can be on an assisted machine) t-bar row, lat pull down, db pullovers, seated row, bent over bar row, db row
These are all good exercises and with most you can change it up just by different grips and hand positions
  • Forged Member
  • Member For: 19y 8m 4d
Posted
Did a bunch of these /\/\/\ last night - came as close as I ever have to throwing up...lol
Started off with bar bell clean and press, then 8min super set of DB Floor Press and chin ups, 8 min super set of bent over bar rows and db post flys. Finished with as many renegade rows as I could - one set with 4kg dbs then just 1 set without the weights....I was rooted!
Got on the treadmill for 5 mins after too...
Dead lifts on thursday, going to push it up to 100 or 110 for 3x6
  • I <3 Floods
  • Member For: 15y 2m 10d
Posted (edited)
So anyone want to explain what a dead lift is?
So far my back exercises are generally Lat Pull Downs, Seated Rows or assisted chin ups.. (can't haul my fat arse up to the bar more then a couple times)..
Edit: I goggled Dead Lifts.. Sounds good.. Shall try it tomorrow..
Edited by Sharp Dressed Panda
  • Forged Member
Posted
With the dead lifts you need to make sure you have good form and your back stays straight. It is really easy to bend your back and throw it out if you do things wrong.
Maybe try to youtube some vids of dead lifts for form.
I try to put the bar on a step box to get it a little higher to start with. The squat rack also has some points on the front of it so if you are tall, you don't have to double over to get the bar back on the ground
  • I <3 Floods
Posted
Yeah I saw a video on a good form power lifting website.. But I thought keeping your back straight and core set was the basis of almost any weight lifting.
  • Forged Member
Posted
Yes that's right, but because you bend right over it is really easy to lose the arch in your lower back it only takes half a second to do an injury - just some friendly advice mate :spoton:
  • I <3 Floods
Posted
I might start fairly light and just focus on keeping my back in form first.. Sorry didn't mean to sound brash there or anything. I appreciate any advice..
Posted
THIS.. because of the nature of the movement and the heavier weight you're very vulnerable so correct form is a must.
Also when doing it, dont go slamming the bar on the ground like most do.
  • Member For: 15y 10m
Posted
If I can add, to help keep your back in the correct position always put your head up and look up while performing the lift, its almost impossible to beand your back while having your head up. Keep the weight light until you and your muscles are conditioned to it.
