Everything posted by kawerx
Wiring Diagrams
you can buy a service manual on cd on ebay.I think it will be in there.I have one,and I will check later.I paid $15.00 dollars for this cd.it has over 2000 pages of info(heaps).
New Wheels
hard to do top speed testing with 750mm of ground clearance.
New Wheels
not a lot of profile on that last one.
Typhoon Drivers
any stories of T's or phoons being floged by moded geminis or corollas? or do people forget to post these? you'll never beat physics:power to weight.
Feeling Something Crawl On Your Thigh?
I have grown fond of this elusive freeloader!
Auto Trans - Feature Or Fault?
did you mean at full throttle or cruising? I hate the auto downshift back to 3rd at around 140 in perfomance mode.it unsettles the car if you are cornering hard. I think mine changes up at aound 190-200 at 100% throttle.about 150-160 when cruising.
Capa Flasher Edit For Xr6 Na
they would make small adjustment to fuel and timing maps.this may mean you need to run premium unleaded. auto firmness and shift patterns may also be changed.
Edit Question
should not delete tune.maybe mechanic made a mistake.was it at ford,maybe they flashed the car back. more likely the mechanic left something unplugged.ask him to check his work,he should have no problem with this if you tell him your concerns.
Bf Xr6 - Got It Today
DONT USE SYTHETIC OIL THIS EARLY ON.let it run in first.maybe 15000. most oil companys make mineral 10w30 oils like valvoline lo-vis oil. im sure mobil and shell make them too.try Repco or supercheap. I went from non turbo ba mk1 to turbo ba mk1.never looked back. both were auto utes the same color.much happier 2nd time round. nothing wrong with non turbo though. im sure the bf would be better than thran the ba as far as noise goes. did you enquire about insurance on a turbo.I think mine was an extra $600 a year. a lot of money but definatly worth it. I dont think it is worth moding a NA.I think if you get into that frame of mind you will end up lusting after a turbo.enjoy what you have-a very nice car.
What Goes Bang At 100psi?
He needs a CUSTOM TUNE!!!!!!!!!!!!!!!!!!!!!!
Changing Oil
I use castrol formula R 0w40 full synthetic. mineral oil for running in. formula r is now called edge. it seems to work for me.I change it every 7500km.my engine is spotless inside.
SELL THE CAR!!! I have had a spider living in my passanger side door mirror from new.06/04. every week or two I wash off the cobwebs and the next day they are back,garenteed. I have never seen this spider in almost 2 years. sneaky barstard!!!
- Dash Light Dimmer
Progress Update: How Is BCL's Car Going?
Wow!first 4 ok no problem. 5th getting happy. 6th way past happy. would you want to take the car to this top speed? dont get me wrong I love high speed driving but will a T's aero handle this sort of speed. I think it might take off.where would you try it,eastern freeway(just kidding)what about a salt lake?This would have to be a record for a T if you could do it wouldn't it? anyone been faster than aps at 307?
Stereo Help?
fusion make a 5X7 split that will fit in the doors quite well.I have these and they are ok. I brought new a pillar covers from ford with the grills for the tweeters in them,like a premium sound set up. these were quite cheap at around $30 each from memory.I mounted the fusion tweeters behind these grills so everything is hidden. or you could just buy the covers and tweeters from ford,this may be cheaper than the fusion splits.
Auto Transmission Oil Change
10 litres
Is It Worth Challenging A Multanova?
a freind of mine received a camera fine a couple of weeks ago.(victoria) 106 in a 100 zone. he went to the infringment office to see the photo. he saw the photo and it had 2 other cars in it. he was told they only take 1 photo. he decided to contest the case and sent in the paper work to go to court. he then receives photo in the mail. gues what,his car is the ONLY car in the photo. he goes back to revenue office and asks to see the origanal photo. his car is the only one in the photo and was told again they only take one photo. sounds to me like the photo was edited to suit their case. he is still going to contest this. good luck I reckon. So look out.the cops have edit too!!!!!
- Gearchange Videos
Hand Brake Not Right...
gee you guys.just a simple hand brake adjustment has everybody worked up. any mechanic worth 2 cents should be able to adjust a handbrake.no tsb's needed. I read the ford service manual fo ba handbrake adjustment.total bs.too complex. is there more to this issue that I missed.from what was described it sounds just like hand brake adjustment. piece of cake.10 min tops.including lifting the car.
The Cars We Drive Being Driven By Music
audioslave for hiway cruising. sound track from crusty demonds of dirt IV for thashing(up to the legal limit)
- Top Speed
Wheel Stand?
sweet! kx250 1st to 5th gear!
Home Tuner Package
injectors need to be able to change injector size what about cold start
Acceleration
imagine what they could do if they had EDIT!
Wheel Stand?
only over a rail crossing in the work ute.mazda bravo non turbo.
