doublek Member 333 Member For: 22y 2m 25d Location: sydney Posted 13/03/06 05:35 AM Posted 13/03/06 05:35 AM hello thereI have a auto xr6t and am thinking of changing the oil and the filter on my 35,000 km service.I have noticed a bit of a whine in 1st gear lately and was wondering if this could be related to the oil? anyone else had this?and is it a good idea to change it early as I think that you are not due for one until the 60,000km mark.thanx
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 4m 29d Gender: Male Location: Victoria Posted 13/03/06 05:38 AM Posted 13/03/06 05:38 AM It certainly won't hurt it.I've done 75,000km and I've changed the auto fluid 4 times.
ms700 Moderating Team 10,170 Member For: 23y 7m 24d Gender: Male Location: Sydney Posted 13/03/06 05:56 AM Posted 13/03/06 05:56 AM I know its overkill, but I change my trans fluid every 10K's.Trans oil gets bloody hot, so its cheap insurance.
turbomuz Member 209 Member For: 21y 4m 11d Location: Canberra Posted 13/03/06 07:11 AM Posted 13/03/06 07:11 AM How do you change the auto transmission fluid? I have done a search and found everything else but not this. I know the best fluid to use has been discussed a couple of times here but I can't find that either? Is the search engine a little less than user friendly or am I just technically challenged?Muz
dingah2 Crusty aviator Member 846 Member For: 22y 3m 5d Gender: Male Location: ACT Posted 13/03/06 08:04 AM Posted 13/03/06 08:04 AM Concur with Mick, it's cheap insurance considering what the tranny goes through - along with a decent cooler as well. Drop the pan so each time you can also inspect certain of the internals and you'll need to factor in a new gasket as well each time. Currently using Castrol transmax Z.Dingah
sutty Mushroom Legacy Donating Member 799 Member For: 22y 4m 9d Gender: Male Location: THORNLANDS, QLD Posted 13/03/06 10:08 AM Posted 13/03/06 10:08 AM It certainly won't hurt it.I've done 75,000km and I've changed the auto fluid 4 times. I know its overkill, but I change my trans fluid every 10K's.Trans oil gets bloody hot, so its cheap insurance. If you drive it hard it aint overkill. I do the same - fluid change every 10,000.
tab Sucker Moderating Team 32,303 Member For: 22y 4m 30d Gender: Male Location: Brisbane Posted 13/03/06 10:19 AM Posted 13/03/06 10:19 AM How do you change the auto transmission fluid? I have done a search and found everything else but not this. I know the best fluid to use has been discussed a couple of times here but I can't find that either? Is the search engine a little less than user friendly or am I just technically challenged?Muz<{POST_SNAPBACK}>In a nutshell - with great difficulty. I wouldn't imagine most of these guys doing it themselves. Although I have been wrong once or twice before.Do you clowns just do a straight change or give it a bit of a flush as well?
GlennAUII Former XT pilot Legacy Donating Member 4,791 Member For: 23y 2m 1d Gender: Male Location: The Womb Posted 13/03/06 10:25 AM Posted 13/03/06 10:25 AM its pretty easy.. I've done it before on my AU. Theres a plate that unclips/unscrews and all the oil drops out, then you just change the filter, wash the magnets inside the plate (to get all the very fine metal dust off them) then put it all back together and fill it up.
FPV TRANNY Im the one and only Legacy Donating Member 3,557 Member For: 21y 8m 17d Gender: Male Location: In my house Posted 13/03/06 10:26 AM Posted 13/03/06 10:26 AM It certainly won't hurt it.I've done 75,000km and I've changed the auto fluid 4 times. I know its overkill, but I change my trans fluid every 10K's.Trans oil gets bloody hot, so its cheap insurance. If you drive it hard it aint overkill. I do the same - fluid change every 10,000.that's why yours is still goin mate Just watch out for that monkey Phil
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 4m 29d Gender: Male Location: Victoria Posted 13/03/06 10:26 AM Posted 13/03/06 10:26 AM its pretty easy.. I've done it before on my AU. Theres a plate that unclips/unscrews and all the oil drops out, then you just change the filter, wash the magnets inside the plate (to get all the very fine metal dust off them) then put it all back together and fill it up.Glenn, what about draining the converter and radiator cooler?
