MUZz1984@ New Member 22 Member For: 8y 6m 2d Posted 12/04/18 01:02 PM Posted 12/04/18 01:02 PM On 4/11/2018 at 7:25 PM, JETURBO said: If keeping it under 550rwkw or 23ish psi you don’t have to... What do you know about xr6t perminace upgradea?
Puffwagon Legacy Donating Member 16,348 Member For: 11y 8m 12d Gender: Not Telling Posted 12/04/18 01:13 PM Posted 12/04/18 01:13 PM #gregnant
arronm Dropping a turd Legacy Donating Member 9,520 Member For: 18y 11m 14d Gender: Male Location: Perth Posted 12/04/18 01:50 PM Posted 12/04/18 01:50 PM (edited) If you are going to rev it up , get a forged harmonic balancer not a cast one.. Why dont you try and find a brand new FG short motor.. It will handle the power you want.. Edited 12/04/18 01:52 PM by arronm
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 4m 10d Gender: Male Location: Adelaide Posted 12/04/18 11:39 PM Posted 12/04/18 11:39 PM I agree with @HI PSI Re: JE pistons, love them and they’re all made per batch and a serial code applied so if you ever destroy one piston you can get an exact replacement ! LOLWUT @MUZz1984@ Agree with @arronm for a cost effective solution regarding a new FG short is ~$3500 and can happily sit in the 500rwkw area as is
4321 Legacy Donating Member 257 Member For: 12y 6m 15d Posted 09/05/18 10:40 AM Author Posted 09/05/18 10:40 AM Engine's back, mostly went with JETS suggestions, JE pistons (+0.020) scat rods, arp studs (head & main) atomic oil pump gears & cover (ported myself after brad said where to enlarge) atomic chain, guides & bottom cog, balancer & flex plate. Torque plate bored & honed , file back rings straighten crankshaft (!) plaz valve springs, ford exhaust valves & head gasket & new heat exchanger. It's mostly back together & intending to change it over this weekend 3
skidxr6t skids Legacy Donating Member 2,754 Member For: 13y 9m 13d Gender: Not Telling Posted 09/05/18 10:59 PM Posted 09/05/18 10:59 PM that's sick man keen as to see the result!
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 4m 10d Gender: Male Location: Adelaide Posted 10/05/18 02:02 AM Posted 10/05/18 02:02 AM Piks !!! 1
4321 Legacy Donating Member 257 Member For: 12y 6m 15d Posted 12/05/18 07:25 AM Author Posted 12/05/18 07:25 AM It's in & running fine, started at 5am this morning & in & running at 1.30! dropped the whole lot out the bottom & changed every thing over to the new engine. That went smooth but changing the radiator- what a crap job (worse than BA_BF) have pics will upload later. Thanks for all the advice! 1
Renton Member 151 Member For: 8y 6m 5d Gender: Male Location: Perth Posted 12/05/18 11:03 AM Posted 12/05/18 11:03 AM
HI PSI Member 1,589 Member For: 20y 4m 16d Gender: Male Location: Central Queensland Posted 13/05/18 04:51 AM Posted 13/05/18 04:51 AM Here are a new set of 0.020" JE forged pistons that have coated skirts and ceramic tops. I picked them up for $1300. There are bargains out there..... 4
