  • Member For: 18y 5m 21d
Posted
Hey all,
Thanks in advance for any light and/or information you can shed. I guess what I really need, is someone in Queensland that knows fords back to front so that I can get my Typhoon fixed. Its now been 2 months since I've had my motor replaced, and it's still running like sh*t and has 1000 issues. None of these issues existed before the motor was replaced, however.
My brand new & built tough motor made 30kw LESS than my old motor that blew up!! The biggest issue is that since ChipTorque tuned it, I can't even go to over take a car without it coughing and spluttering like a bucket. I mean really, who lets a car go from their workshop that runs like sh*t? If I try to boost it harder, the car literally rocks back and forth from the power surge that is unleashed. On top of that, when you do put the throttle down a bit, the dash lights up like a christmas tree - hand brake light, ETC light, traction and a few others. THEN, the speedo will die after those lights come on, and I have to pull over and turn the car on and off so I have a speedo again.
I've taken it into 3 local ford dealers, all of them no help AT ALL. They all want to charge me $200-$300 for diagnostics, and at the end of that, they have no answers for me and no way to assist me, just blame it on my 20" wheels and 4" exhaust - but these electrical problems didn't exist before the motor was replaced.
So, who's a good tuner/mechanic that might be able to actually be able to fix my car? Or at least want to try and fix it? Because right now, I might as well not even have the car at all, it's pretty much worthless and useless in the state its in.
As said, any help or direction will be awesome. I'm located in Ipswich, but will drive long distances if it means my car being fixed.
Cheers, Mitch.
  • 12" member
  • Legacy Donating Member
  • Member For: 21y 3m 13d
Posted
have u taken it back to Chiptorque and said WTF ??
  • Member For: 18y 4m 27d
Posted
Give Jamie at fpt a call or Clinton from profile performance both know these cars very well and aren't too far from you.
  • HOON
  • Member For: 16y 6m 22d
Posted
Take it back to chiptorque if it isnt fixed to standard then go to consumer affairs and you'll either get compensated or they will let chiptorque fix the issues under supervision and pay for the service
Posted
Thanks guys, got a good recommendation to go see Elite, so I gave them a call, they were great! Helpful and friendly and even has a few ideas on what may be causing it - booked in for 15th August so see how we go, fingers crossed!!
  • Member For: 19y 6m 4d
Posted
good to speak to you mate!!!
Look forward to meeting you and sorting through your issues!!!
  • Member For: 16y 11m 12d
Posted
"If I try to boost it harder, the car literally rocks back and forth from the power surge that is unleashed. On top of that, when you do put the throttle down a bit, the dash lights up like a christmas tree - hand brake light, ETC light, traction and a few others. THEN, the speedo will die after those lights come on, and I have to pull over and turn the car on and off so I have a speedo again."
I had the same problem, turned out to be connections where the coils plug in
  • Member For: 16y 8m 19d
Posted
As for the handbrake light you mentioned that actually isnt the handbrake light but a warning light. Its a pity its so similar, you can replicate the lights by pulling the abs fuse out under the drivers fuse bored.
You will get all the lights mentioned and the lose of speedo with that fuse out.
As for you other issues sorry but cant help ya there. Are all the fuses good?
  • Member For: 18y 8m 7d
Posted
Make sure your ECU connectors are all the way home and clipped correctly. If they were rough they may have even bent some pins. Sounds like a connector or earth problem.
  • BOOST
  • Moderating Team
  • Member For: 23y 1m 2d
Posted
Trade it in :wacko:
