Everything posted by F6BF
Fg F6 Engine And Diff Oil
Or AFL-101 motorcraft brand
My New Fg F6 310
Traded the old girl in BF Typhoon for this new baby FG F6 310, 6/2010 last of the euro 3's winter white, leather, dark argents, ZF, pick her up next week Pic at the dealer, more pics to follow
Beefing Up The Zf
125,000km factory ZF still alive, using castrol transmax Z from 20,000km
Fpv Fg F6 Short Motor From Ford Dirt Cheap
Pistons are upgraded on the FG F6, everything else is the same
New Addition To The Zap Clan
Congratulations mate
Need A New Radiator
Whats the pwr and plazmaman worth ?
Elites Fg At Heathcote
Nice ride and pics paul
Spotted Mobile Speed Camera Car Thread
Silver territory with orange stripe down the side on the M7 just before the m4 interchange
New F6 - June 2010 - 321Kw , Over 600Nm
From what I have been hearing F6 will have the same power just new cat and software calibration for euro 4 No V8 till october discounting on F6 to boost FPV sales to follow, heard from a mates brothers cousin sister lol
Fpv To Supercharge New 5.0-Litre V8 To Give Ford A Power Boost To Riva
Power will remain the same for F6, just a cat change and software upgrade to meet euro 4 SC XR8 to roll into production July
Oil In Water Coolant
Hectic dude's F6 is manual so cant be the radiator, more likely to be the head gasket
Trouble Launching Zf With Mt Street Slicks
Your tuner can fix this so u can boost off the line
Have heard 335 mentioned a bit
Aftermarket Sump Gasket And Filter For Zf Auto
Motospecs - 4 blissington st springvale vic ph. 03 9540-3419
Using Slicks With Out Runners
Radial tyres will react much quicker, while crossply tyres are much slower to react, therefore if u mix the two car will want to wonder left to right, faster u go the worst it gets Always use; Radials with Radials Crossplys with Crossplys
Twelve Months Of Coil Pack Research
Im still running standard coils also, have clocked up 90,000km with 350 to 400rwkw
What Fuel Do You Use?
Shell V power is only 95ron in most states now I like United 100
Who Here Has A C4 In The Xr6T Pros/Cons?
Saved this from another forum C4,5,9 and C10 are all basically the same trans with some differences between them. These are some of the differences: C4 - Smaller 24 spline input shaft Bellhousing and pump share same bolts trans casing has a 'step' at the front near the bell filler tube enters case breather tube exits case near selector lever C5/C9 - Larger 26 spline input shaft Bellhousing and pump share same bolts trans casing has a 'step' at the front near the bell filler tube enters case breather 'cap' in trans extension housing at top C5 pan has larger capacity than C9 pan C10 - Larger 26 spline input shaft Bellhousing and pump use seperate bolts trans case has smooth transition to bellhousing mount filler enters pan breather 'cap' in trans estension housing This is how to id them externally. There are minor differences internally so some parts won't interchange, ie valve bodies. C10 Bellhousing won't fit C4,5 and C9 however C4,5 and C9 bellhousing will fit C10 with longer pump bolts. I believe all C10 bellhousings are designed for the larger 164 tooth flex however C4-C9 housings are available for 164 or 157 tooth flex. C5,9 and C10 are slightly stronger due to larger input shaft. Beyond that there ain't much difference. Things to watch when swapping is to use the correct bellhousing and converter(24 or 26 spline, 157 or 164 tooth flex compatibility) and also use the correct valve body if swapping.
Rebuilding Zf's
Jman, does that price include the convertor? I am rebuilding one atm and have found parts to be fairly cheap for a german transmission
The End Of The World!
Breaking News: Just been revealed were the dust storm started from.........................St George leagues club, when they opened their trophy cabinet
F6 Vs G6E Turbo
Both have the same power, g6et should get the jump as it comes on boost quicker g6et owners have recorded 12.8 ets so no slouch
Premium 100 Fuel
that's were I get mine from
Zf - Steal Pan Sump/Bolts & Penrite Trans Oil
My zf has been running transmaxZ for the past 3 years and 75,ooo km, Has seen the strip and over 400rwkw, still going strong
New Pb At Wsid
Went through my time slips when my car was stock 235 rwkw and found one with very similar et to yours jaymen [email protected], 2.071 60ft, I have a few other 12.9 timeslips and all at 108mph, this is with the ZF trans What mph were your other runs, could be u backed of early before the finish line?
New Pb At Wsid
.661 would be your reaction time Well done on the PB
