mc03 New Member 4 Member For: 1y 1m 18d Posted 02/05/24 12:56 AM Author Share Posted 02/05/24 12:56 AM If you press the button on the switch does it fix itself? You can always bypass the switch for a while to see if that fixes it. If so, switch is probably faulty, Ford still sell them brand new for about $90. @TobyXR6 This is sounding incredibly similar. I've traced mine back to the same thing - a lack of grounding on pin 926. However I've never had the starter motor fail to activate (yet...). I also haven't noticed any correlation with heat. More often than not mine occurs on a cold start when the car has been sitting for a while (not daily driven). I was planning to do the same and install a manual override switch for the fuel pump but was also concerned about safety. My idea was using a two stage switch, where you had a toggle switch run in series with a signal that was only live when the engine was running (first thing that comes to mind is oil pressure switch), and then a push button switch that would be a full override? Flip the switch, hold the push button to start (100% override), and then the toggle switch + oil pressure switch will keep the fuel pump switched on as long as the engine is running. This would at least cut the pump in a scenario such a broken fuel line. You also have the inertia switch which would cut the pump in certain types of accidents, and that still functions as normal with the relay manually switched on. As for the P0230 DTC being caused by your override switch, I think it's a definite possibility. Unless there is some other PCM connection to the secondary circuit that I'm not aware of, the PCM doesn't really know whether the fuel pump is on or not, but your override switch would be causing the PCM to "see" a ground that it didn't ask for. If you wanted to fix this, what if you added your own independent fuel pump circuit, by running your override wire to a new relay instead of the existing one and leaving the PCM out of it completely? Hearing that your PCM has been bench tested as normal gives me a bit of hope to keep diagnosing this instead of replacing my PCM now. @BarraT Could be on the right track with the grounding issue. @TobyXR6 Have you checked all your grounds yet? This is the next thing on my list. Maybe your issue is a bad ground somewhere that becomes more interrupted with thermal expansion around it? That would explain the heat correlation. One interesting thing I observed was that if I kept the car on a trickle charger and kept the battery voltage maxed out, it seems to happen a lot less frequently. Have you looked into battery voltages / battery health / parasitic drain at all? Does the car hold charge long term or will it drain over time? I know mine has a small drain, narrowed down to something on the BEM fuse (haven't diagnosed exactly what yet). I realise all these suggestions are band aid fixes and don't really work towards finding the actual issue, but hopefully some of them are still helpful. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/97207-ba-turbo-pcm-fuel-pump-issues/page/2/#findComment-1722924 Share on other sites More sharing options...
FGboy New Member 4 Member For: 11m 18d Posted 02/05/24 03:47 AM Share Posted 02/05/24 03:47 AM @mc03 if I press the switch it will allow me to lock the doors but not able to start due to fuel cut off switch being activated again, but sometimes the error will go away and then able to start but then the pumps keep running while ignition is on. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/97207-ba-turbo-pcm-fuel-pump-issues/page/2/#findComment-1722929 Share on other sites More sharing options...
TobyXR6 Member 7 Member For: 19y 8d Posted 07/06/24 07:58 AM Share Posted 07/06/24 07:58 AM OK, I haven't given an update as although the problem hasn't reoccurred (despite it happening, pretty much every time we drove it), I can't give an exact reason why it is fixed as I did a bunch of things and one of them may have fixed it or perhaps (since it was a temperature related issue) it isn't fixed but winter temps have made it go away (for now....). But, considering how it hasn't faulted in a month or so, I thought I'd share some of what I did and some comments regarding what these might have achieved... A recap: Fuel pump relay would turn off after the car was running (particularly in heavy traffic) for a while and then the starter relay would not work. Sometimes, after a short drive and parking for a while (while shopping or whatever - and some heat soak occurred under the bonnet), the fuel pump relay and starter relay would not work until the under bonnet temps cooled down. Once the under bonnet temperatures had cooled down, it would start again. I traced the problem to being a loss of signal from the PCM to these relays (the PCM grounds the low side of the coils in these relays, to allow the PCM to allow them to turn on/off) - I.e. the PCM was turning off these relays. I was able to confirm this by measuring the signal at the PCM connector (by running a diagnostic wire all the way to - and inside - the PCM connector). What I have done since last post: I replaced the cooling fans and shroud because (coincidentally), just before sending the PCM off, the outer ring of one of the fans failed and was rubbing on the shroud. I had sent the PCM off to Injectronics who tested it and could not fault it on their test rig, they returned it but I couldn't immediately start the car as while fitting the cooling fan shroud, the small plastic outlet at the side of the radiator cracked (and I was in the middle of doing 5.). Although (2) was annoying, I've noticed the car had been running a bit hotter than normal (not too bad, but the needle in the temp gauge could point - almost - straight up, if the car was stuck in traffic for prolonged periods), so it was time for a new radiator soon anyway. When I replaced the radiator, I did a complete flush (with coolant flush) and did several water flushes afterwards so when the new (Ford) coolant went in, it would be nice and clean. BTW, the old coolant was a nice green colour (no rust in the coolant) which was not surprising as I regularly replace the coolant. I cleaned (thoroughly) the battery terminals (which for a LONG time) were getting that white/blueish powdery build-up on them. I also bought some CRC Battery Terminal Protection spray, and sprayed the battery posts (thoroughly) before reconnecting the terminals. I (unrelated to the issue, but this is another reason for the slow update), I removed the IRS and replaced all the rear suspension and diff bushes. What could have fixed it: Nothing, it could still be faulty, as the weather is now cooler and the new radiator is now working more efficiently, so maybe now, the under bonnet temperatures are low enough for whatever was failing to no longer fail. 1a) Although I don't think this is the case, the air off the radiator blows straight onto the crank sensor (which, if not giving the PCM the right signal, the PCM might assume the engine has stalled and turn off the fuel pump). I doubt there's anything wrong with the crank sensor as, when I (earlier) had used my switch to ground the signal (that goes to the PCM to allow the fuel pump relay to run), the signal from the crank sensor was good enough for the other functions used by the PCM to still allow the engine to run perfectly fine. However, it is possible that the PCM (somehow) uses the crank sensor in different ways (for ignition timing and for fuel pump relay operation) such that it works OK for the ignition timing, but the PCM still didn't consider the signal good enough to allow the fuel pump to run (BTW, there were no crank sensor error codes). I doubt this too, but I don't know how the PCM code is written (despite reading the Ford Manual, which has quite a bit of useful info, but not enough to know for sure). 1b) Again, although I don't think this is the case, it is possible that some other component under the bonnet (the PCM itself) was being temperature stressed and either going into fault, or faulting enough that the PCM decided to turn off the fuel pump. I doubt the PCM was turning off the fuel pump due the PCM getting temperature stressed as Injectronics thermal stressed it as part of their tests (I rang them - both the first time I sent the PCM to them, and again the second time, where I had quite a long discussion regarding their testing and I feel pretty confident they've stress tested it more than it was being stressed by a slightly inefficient radiator was causing). When I read the Ford manual, I also couldn't see any other sensor that (if failed) would give the same symptoms. The PCM and/or some sensors were getting a "bad earth" signal (due to the battery post corrosion/build-up) and this was causing the PCM to turn off these relays. My brother is an (very experienced) electrical engineer and a "bad earth" was one of the things he suggested I look at when the problem first occurred. I did check (with a multimeter) the condition of the earth at the PCM (when originally diagnosing the problem) and I could never find a problem with it (always less than an Ohm or so) but I know from my experience as a mechatronics engineer, that poor earthing and sub optimal connections can cause intermittent (and difficult to identify) problems, particularly with low voltage signals (such as you find under the bonnet of a car). To be honest, I only decided to buy the Battery Terminal Protection spray to rule it out (more out of frustration, and a desire to rule it out) and I'm not saying this fixed it, but it is a real possibility that the problem was a simple as that. There was a problem with the connection from the PCM PCB to the pins where the engine loom connects, and Injectronic's work of removing and replacement of the original and (later) their sealant around the cover plate under the PCM aluminium housing, has flexed the PCB and/or pins in such a way that the connection (which - assuming the connection was bad in the first place), now is a better connection and no longer effected by thermal stress. I doubt this to be the case, but I guess it is possible. I really don't feel confident the problem is fixed but since the problem was occurring VERY frequently (almost always on every drive), and now it hasn't faulted once in the past month or so, I think option 1 is unlikely (I'll update this post if the fault occurs again). I don't think option 3 is likely as I suspect the connector pins are soldered directly onto the PCB and the silicon sealant (for the cover plate) is unlikely to provide sufficient force to fix a dry solder joint (BTW, Injectronics remove this cover to visually inspect for dry solder joints and couldn't find any - both times they had it). So (despite finding it a bit hard to believe that the battery connection was good enough to allow BIG currents to flow when the starter motor was cranked, but bad enough to upset a sensor's signal to the PCM), at this stage I'm thinking it is option 2... BTW, the P0230 error code might have been a bit of a red herring, as I was (when the fault occurred, effectively) grounding the fuel pump's starter relay (to over ride the ground signal that the PCM should have provided, so we could continue to drive the car) but in doing so, I was also grounding that pin on the PCM (which the P0230 fault is reporting - there's a short on the fuel pump relay signal). So, my over-ride method may have been the cause of the P0230 error code after the fault (whatever it was) had caused the PCM to stop allowing the fuel pump to run... Anyway, sorry for the long explanation but I know how frustrating this fault is (I've been battling with it for over a year now) and I figured some feedback of what I did (even if it is a bit long), is better than nothing at all. If you have this problem and are able to fix it (definitively), please let the forum know :). Toby 1 Link to comment https://www.fordxr6turbo.com/forum/topic/97207-ba-turbo-pcm-fuel-pump-issues/page/2/#findComment-1723164 Share on other sites More sharing options...
TobyXR6 Member 7 Member For: 19y 8d Posted 07/06/24 08:09 AM Share Posted 07/06/24 08:09 AM @mc03 Your solution of a separate switch to ground the fuel pump relay and use the oil pressure switch to maintain this ground was exactly what I was going to do if I couldn't get to the root cause. Fortunately/unfortunately, the problem has not reoccurred (see above post) since doing a bunch of things. My plan (if the problem persisted) was to use a timer relay in conjunction with the oil pressure signal such that on starting, the timer relay would provide the ground for a few seconds before turning off which, by then, the oil pressure switch would provide the ground. That's how they used to do it before PCMs/ECUs when changing from a mechanical fuel pump to an electrical one. Back in the days of carburettors, you didn't even bother with the timer relay as there was (normally) enough fuel in the float bowl to allow the engine to start before there was oil pressure and fuel pump would start up... I hope you can get to the root cause though, as this problem is VERY frustrating and I too considered buying another PCM (at a quoted price of $1200) as I couldn't bring myself to having a non standard way of operating the fuel pump... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/97207-ba-turbo-pcm-fuel-pump-issues/page/2/#findComment-1723165 Share on other sites More sharing options...
BarraT Member 34 Member For: 5y 2m 30d Posted 09/06/24 10:19 PM Share Posted 09/06/24 10:19 PM (edited) Excellent Info Thanks If the fuel pump motor has been pulled out and checked and it isn't shorting to ground Then check your fan relays, they play havoc with the car electric system, when these fail, yes, true, you will notice the temperature rising in traffic, if the low speed fan isn't kicking in at 100C Edited 09/06/24 10:23 PM by BarraT Link to comment https://www.fordxr6turbo.com/forum/topic/97207-ba-turbo-pcm-fuel-pump-issues/page/2/#findComment-1723195 Share on other sites More sharing options...
