  • Member For: 4y 4m 24d
Posted
hey guys
will I need to port the rear housing if I am using a turbo side intake,flow though intercooler an plazmanside coldside piping with stock turbo back exhaust running the stock actuator ?
I also have the stock intake set up if needed.
  • less WHY; more WOT
  • Site Developer
  • Member For: 18y 5m 23d
Posted
no, you don't need to port the turbo with just a turbo-side intake.
  • Thanks 1
  • Legacy Donating Member
  • Member For: 20y 9m 15d
Posted (edited)
No you wont need any wastegate porting for that. But if you modify the exhaust with a hi flow cat and dump pipe system you will then.
Edited by JVK
  • Thanks 1
Posted
yes I was asking if I need to port the wastegate if I am running the stock turbo back exhaust.. just not wanting any over boosting issues. using the stock 5psi actuator
  • Site Developer
Posted
you'll be fine
  • Site Developer
Posted
you should get a boost controller, even if it's to run gate pressure but spool quicker :)
  • 4 months later...
  • Site Developer
Posted
It would, but it's harder to tune as you need to adjust the manual controller and then separately adjust the tune which some tuners hate doing that... Electronic boost control is obviously better. Most tuners enjoy the control you get from the factory boost control
