Dat111 Member 30 Member For: 4y 4m 13d Posted 03/11/22 05:07 AM Author Posted 03/11/22 05:07 AM going factory is a little bit harde.as having a BF MKII ZF box -.- an cant change the spring in the Garrett wastegate. as its a sealed unit. boost TEE from what ive read wont do what im wanting, flatten the boost curve/spool a little quicker.
Puffwagon Legacy Donating Member 16,348 Member For: 11y 7m 24d Gender: Not Telling Posted 03/11/22 06:46 AM Posted 03/11/22 06:46 AM You can get a Garrett actuator that will bolt in that has higher spring pressure
SHRL3Y New Member 4 Member For: 3y 10m 15d Posted 07/11/22 05:39 PM Posted 07/11/22 05:39 PM Def get a boost controller . I have the e40 little square 1 . Looks Better than the round new 1 . That way u can tune it perfectly and set all your boost pressures and when to stop so no over boosting. But soon u will get bored and keep poring money in to it with upgrades that she the boost controller is best. Has different set ups so u can cruise on like 10 pounds then push the button and change and give it the 24 pounds as I’m running atm.
