kamanli New Member 8 Member For: 8y 1m 4d Posted 21/01/17 11:07 PM Share Posted 21/01/17 11:07 PM Hi All, I have an older ba xr6 turbo with 200,000klms and would like to spend as little as possible with max gain, I have been advised by a friend with a modded xr6 turbo to go for some bigger injectors, bigger intercooler and a tune (possible a dump, high flow cat, delete mid). I will try to find all these second hand to keep costs lower. The car is completely stock, just has a kn filter. I have recently also purchased a earls oil line filter. I am aware there is many older threads but I was after up to date info as there would be newer products than was available in the past. Also if you have any parts I could use please let me know I am located in sydney. Thanks in advance Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,310 Member For: 16y 17d Gender: Male Location: Melbourne Posted 21/01/17 11:11 PM Share Posted 21/01/17 11:11 PM BA with 200,000km+ is a potential ticking time bomb in terms of the skinny rods and the weak auto/manual gearboxes that both let go at ~300. You'll have issues getting reliable power out of it for not much money, but your friend is reasonably on the mark for the simpler power-adders for these cars. Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 1m Posted 21/01/17 11:14 PM Share Posted 21/01/17 11:14 PM Injectors, pump, high flow cat, holes in air box base, better intercooler & tune Link to comment Share on other sites More sharing options...
kamanli New Member 8 Member For: 8y 1m 4d Posted 21/01/17 11:19 PM Author Share Posted 21/01/17 11:19 PM Awesome its good to know I am on the right track, hopefully I can find the parts for a reasonable price. 300 is more then enough for me for now I guess, its never enough Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,133 Member For: 9y 2m 29d Gender: Male Location: South Australia Posted 22/01/17 12:00 AM Share Posted 22/01/17 12:00 AM Spending as little as possible for max gain from stock is just injectors, fuel pump and tune. Sure the cat, cooler, exhaust etc will help but that isn't keeping it as cheap as possible. You mentioned that it's never enough so make sure you plan it out so you don't pay for things twice eg: tuning or poor quality parts. 1 Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 7y 11m 8d Gender: Not Telling Location: Radioactive wasteland Posted 22/01/17 12:36 AM Share Posted 22/01/17 12:36 AM @BAXRTUTE might be able to help you with a fair whack of goodies. He had cooler pipes and under battery intake with 62 pound injectors. https://www.ebay.com.au/itm/112053782109 that'll work with most intercooler pipe kits. Get a walbro 460lph intank pump. Bash your cat out and find someone with hptuners near you to tune it. You'll probably get close to 250-270rwkw. Doing it on the cheap isn't the way to go. I've been tempted a number of times but I'm holding out to do it right. Don't let us stop you but. Post up your progress. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 5d Gender: Male Location: Canberra ACT Posted 22/01/17 12:44 AM Share Posted 22/01/17 12:44 AM If your cat is 200k old it's probably pretty clogged too which adds weight to the idea of replacing it or bashing it out. They are surprisingly cheap if you don't want to just gut it. Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 9y 20d Posted 22/01/17 01:20 AM Share Posted 22/01/17 01:20 AM All the above information is spot on the mark buddy. I was at the exact some place you were almost 2 years ago. One thing that hasn't been mentioned is Valve springs. It was my first port of call after the flash tune. Definitely fuel pump Walbro Injectors don't skimp on these. ID'S ftw Bolt in cat section. $500-$650 Flea bay Shouldn't need to change the dump pipe. I'm at 315rwkw's on standard dump and cat back exhaust. Just upgraded the Cat section (Venom) It's holding it back a little bit but on a BA MK2 I can't go much higher anyway. Don't let Keith scare ya 200+ k's on a BA isn't any real issue if it's tuned correctly. Jet has mine sitting very safe at 14 psi with more room to move with a more flowing exhaust. 340 rwkw's on the same psi is my max number he will push it to. And that's still safe..... The famous words come to mind. How long is a piece string. A person who doesn't want to spend much money on these cars will always spends double. As Rob and puff said save up and do it all at once. I enjoyed the journey of doing it in stages, my wallet not so much. Hahaha..... Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 11y 11m 23d Gender: Male Location: Central Coast Posted 22/01/17 02:38 AM Share Posted 22/01/17 02:38 AM Being a stinge is ok if you do it smartly, ask me how? Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 4m 2d Gender: Male Location: Melbourne Posted 22/01/17 03:32 AM Share Posted 22/01/17 03:32 AM dont gut your cat get a high flow one 100cell at least. bad people! Link to comment Share on other sites More sharing options...
