SipposBFT Member 81 Member For: 17y 1m 2d Posted 24/06/16 11:56 PM Posted 24/06/16 11:56 PM Hi All yes like many of us XR owners around Aus... The stage 1 tune has lost it's appeal & now bigger things are on the card. Just want to confirm that've there's no reason I can't build a NA barra engine into a turbo? Would I be better off going for a BA/BF or FG donk? The plan is spool rods/forged pistons, arp head studs & crow springs/retainers. Of course a standard reco of the head is also in the plan. Head gasket recommendations? My plan is to tune this to 450rwkw. Any other advise would b awesome cheers
bossmang FREAKY Legacy Donating Member 12,441 Member For: 16y 8m 29d Gender: Male Location: Melbourne Posted 25/06/16 12:05 AM Posted 25/06/16 12:05 AM if sticking to the 450kw area just buy a FG f6 short motor throw it in away you go. throw in head studs/ valve spring, all your bolt on ons and your good. assuming a good tuner is used as well. 1
skidxr6t skids Legacy Donating Member 2,754 Member For: 13y 8m 26d Gender: Not Telling Posted 25/06/16 12:18 AM Posted 25/06/16 12:18 AM build a high compression motor just for E85 hahahha but watch out you'll probably have mattyp come and actually recommend this. 2
Trent0 The Toxic Rocket Legacy Donating Member 574 Member For: 16y 4m 29d Gender: Male Location: Brisbane Posted 25/06/16 12:45 AM Posted 25/06/16 12:45 AM If I were to do it all again, I'd just do valve springs, oil pump gears, head studs, rods and freshen up the head. (assuming bottom end is mickey mouse)
Tocchi Sandtrap Motorsport Legacy Donating Member 2,055 Member For: 17y 9m 29d Gender: Male Location: Perth Posted 25/06/16 01:12 AM Posted 25/06/16 01:12 AM Just go FG F6 engine - with headstuds, oil pump gears & valve springs .... At times I feel I should have done this
gaz097 Legacy Donating Member 1,752 Member For: 15y 2m 2d Posted 25/06/16 08:10 AM Posted 25/06/16 08:10 AM Boost in the mid is when you want them forged rods. Life begins at 26psi. 2
BAXRTUTE Legacy Donating Member 2,639 Member For: 10y 5m 5d Posted 25/06/16 08:49 AM Posted 25/06/16 08:49 AM Im having the same head funk atm with this, You can 100% do a NA build, id go which ever motor has done the least km. Ive been looking over Atomic 698 phase 2 kit Or Spool kit, or F6 short. F6 short will get 95% of the way id like to one day go, Atomic 698 is all the way and then some, the price difference is about 10k though Ad to that a full drive line transplant = FARK
SipposBFT Member 81 Member For: 17y 1m 2d Posted 26/06/16 02:26 AM Author Posted 26/06/16 02:26 AM Thx 4 the input guys ... Question... F6 has same rods as XRT ? Think I want a bit more re-assurance than this... Where do I get pump gears from? These just increase flow or pressure? E85 has crossed my mind.
MattyP MattyP Legacy Donating Member 6,317 Member For: 14y 4m 19d Gender: Male Location: Central Coast Posted 26/06/16 02:51 AM Posted 26/06/16 02:51 AM build a high compression motor just for E85 [emoji14] hahahha but watch out you'll probably have mattyp come and actually recommend this. Well you want the best bang per litre high comp boost on e85 is the way to go All about that BSFC! But in reality most aren't huge fans of efficiency like I am or have access to ethanol close by. The standard low comp pistons are incredibly versatile. Can even run 94e10 @365rwkw and done 12 flat on it with huge gearbox issues. Fg f6 has a stronger short block than the xr6s, I believe it's bigger rods. Best to ask the guys who've pulled em apart 100 times Who's your tuna?
SipposBFT Member 81 Member For: 17y 1m 2d Posted 26/06/16 11:57 AM Author Posted 26/06/16 11:57 AM Won't do a high- comp turbo to run on E85... Wud just consider tuning on E85 4 extra tuneable power ... I have the Herrod E85 compatible pump so it allows the option... My tuner 4 current tune is Tunehouse... But am considering spending a few weeks in Melbourne for a holiday & getting Nuzpro to fit the upgraded ZF box & tune ... They're proven & cheaper than tunehouse
