HI PSI Member 1,589 Member For: 19y 1m 20d Gender: Male Location: Central Queensland Posted 09/12/15 12:30 PM Author Share Posted 09/12/15 12:30 PM This looks promising.... http://www.mooregoodink.com/news/worlds-first-sequential-transmission-for-corvette/ Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573296 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 22d Gender: Male Location: Perth Posted 09/12/15 12:42 PM Share Posted 09/12/15 12:42 PM Stock shifter is mounted via a rubber damper. Reduces the feel and can lead to movement between the lever and shifter. When I modded my old car a had some bushed in steel tubed up to bolt the lever directly to the shifter. Massive improvement in feel and precision at the expense of noise. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573301 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 11m 23d Gender: Male Location: Hills District, NSW Posted 09/12/15 09:09 PM Share Posted 09/12/15 09:09 PM I use a steel adaptor box as well, but with a couple of rubber gaskets on each side to decouple the noise. Makes it quiter than stock. Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573312 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 11m 24d Posted 09/12/15 10:11 PM Share Posted 09/12/15 10:11 PM How does this wot box work? If it's a ignition cut when you activate the switch how do you actually put it in gear and take off without it just cutting the ignition. Is it speed sensitive or have some other input for stopping and sitting at lights? Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573315 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 25d Gender: Male Location: Brisbane Posted 09/12/15 10:33 PM Share Posted 09/12/15 10:33 PM (edited) Can be set up via load or accelelerator pedal position, so it only comes into play at 3/4 or more for example. Might even be able to do speed as well so you can launch it. Will mean no more clutch kicks but I imagine..but from what toads was saying it can be turned on and off? Edited 09/12/15 10:33 PM by barnz Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573317 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 22d Gender: Male Location: Perth Posted 09/12/15 10:35 PM Share Posted 09/12/15 10:35 PM Throttle position and clutch switch position. Unless you have you throttled matted and clutch in it won't activate the two step, ign cut requires a present throttle position, clutch switch input and rpm above a present value. Re solid mounted shifters - protip superpro Sway Bar link bottom bushes are the correct size for the shift lever on a b series and are a nice mix of noise isolation and stiffness improvement. Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573318 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 20y 7d Gender: Male Location: OZ Posted 10/12/15 02:50 AM Share Posted 10/12/15 02:50 AM The RPM above a preset level is for the two-step lock-out RPM. I.e. I have the two-step disabled about 1500rpm so I don't be silly. The WOT BOX itself is cheap but you need an Opt 6 or equivalent clutch and a built rear end. Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573332 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 5m 14d Gender: Male Location: Sydney Posted 10/12/15 06:55 AM Share Posted 10/12/15 06:55 AM A hard mounted shifter with a ign cut on shift would blow your mind.Srsly wrap the portion of the stick that's under the boot in dyna mat. Makes a massive difference to the resonance. I have some off cuts I could send you if you don't want to rush about and buy a pack.^^^^^^^^^^ see now that there is why you are on the big buckssounds like a perfect job for me when im at work on Xmas day...... Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573349 Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 15y 2m 20d Gender: Male Location: Brisbane Posted 10/12/15 07:55 AM Share Posted 10/12/15 07:55 AM Stock shifter is mounted via a rubber damper. Reduces the feel and can lead to movement between the lever and shifter.When I modded my old car a had some bushed in steel tubed up to bolt the lever directly to the shifter.Massive improvement in feel and precision at the expense of noise.So I've just pulled my stick out to suss it all and I see the stick holes are heaps bigger than the base top holes. You said you used bushed steel to fill it up?Keen to give it a go Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573352 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 22d Gender: Male Location: Perth Posted 10/12/15 08:05 AM Share Posted 10/12/15 08:05 AM Yes I had some top hap bushes machined up,then had to flat off the sides for clearance. Toads or Turboknapp should be able to post a pick at some stage as they have a set each installed. Link to comment https://www.fordxr6turbo.com/forum/topic/91469-t56-shift-mods/page/7/#findComment-1573355 Share on other sites More sharing options...
