  • New Member
  • Member For: 10y 11m 27d
Posted (edited)
Hi all! Just joined and this is my first post. Just got myself a stock 2011 FG xr6t. This is my first ever build and hoping for over 500rwkw. The mods I have sitting here to get fitted are as follows:
*Garrett gtx35/40 with upgraded actuator
*Plazmaman 1000hp intercooler kit
*plazmaman surge tank twin 044s and wiring loom
*ID 1000cc injectors
*x force 4inch stainless steel exhaust
*atomic ovate race valve springs
*set #4 flash tuner
*arp stainless head gasket and head studs
Any thoughts on my plans before I send it in to get installed would be greatly appreciated as this is my first build.
Thanks in advance :)
Edited by Timfg
  • Legacy Donating Member
  • Member For: 20y 9m 10d
Posted
Welcome to the forum. Fg is a good platform to build up from and you certainly have a good list of parts to make it into something special.
But in my opinion what you have will put you in the 400 + rwkw , maybe 450 ?
500+ rwkw is a high number to expect from this combo and if that is the plan you might want to look at better conrods and pistons as well as a modified oil pump.
There are a few decent build threads on the this forum just have a read and you will pick up good pointers as well as find out who are the right people to ask for info.
Good luck with the build and keep us updated.
  • ...JD TUNING ADELAIDE...
  • Member For: 18y 3m 28d
Posted
Welcome mate but as above has said you won't get over 500 with the combo at hand but have every chance at the 450 zone on E85
  • Member For: 12y 10m 8d
Posted
Diddnt cms do a manual ute that made just a touch over 500rwkw on a stock engine (fg)
Is it still alive? In any case 500rwkw is well in the danger zone for a std donk
Posted
Seen stock FG engines go 560rwkw before
Also seen some blow up
  • Like 2
  • in the mid....not the bum like some
  • Member For: 13y 5m 5d
Posted
What's holding it back if the tuner leant on it a fair bit?
Im sure the OP would like to know also ;)
Posted
Why don't you explain it since you're so up with it all gilly
  • Member For: 14y 2d
Posted
Feel like I should ask if you are used to cars with that kind of power at all? haha. Or you are just trying to get to 500rwkw for the number? 400-450rwkw is still massive power for a street car, honestly at the brink of what you'll actually be able to use on the street.
  • Moar Powar Babeh
  • Member For: 21y 5d
Posted
400 is well past usable power on the street in these cars.
Anything about 370 odd rwkw (imho) only kills tyres or hard parts if your run decent tires.
  • Like 4
Posted
How about you worry about yourself Jet and not others so much?
Grow up FFS!
