  • Member For: 12y 10m 13d
Posted
ratter , so a 2 litre turbo engine that has 200 hp and a turbo 6 that has 200 hp have the same torque ? just asking
That's not what he said, if those 2 engines were making the same power at the same rpm the maths tells us they have to be making the same torque
  • Member For: 12y 8m 5d
Posted (edited)
ok so only the same type off engine ? but I thought torque is low down power ,nothing to do with up higher rpm ?
Edited by genuine honest person
Posted (edited)
Forget the type of engine.
No, you will make more power down low the more torque you make down low, once rpm is up it becomes the more significant multiplier, look at the calculation again.
This is just my understanding anyway
Edited by barnz
Posted
ok , just hear what I am saying (I will be wrong again as always ) but my turbo was very lagy down low (found out that the turbo builder accidently fitted the wrong wheel ) so what I am getting at small turbo v big turbo , same 300 kw . do they have the same torque ? I am a simple minded person so please explain
  • Member For: 20y 4m 6d
Posted
Barnz is spot on, engine variety, size etc it does not matter when comparing same numbers at same rpm
Posted
because it has more boost at a lower rpm, so the torque and power is higher at that lower rpm
  • Like 3
  • Legacy Donating Member
  • Member For: 18y 10m 12d
Posted
Gunna, in the vehicle technical section of this forum
There is a sticky thread about this, it explains it all in a simple sort of way
(I'm on tapatalk so have no idea how to add a link to it)
Also turbo lag affects the feeling it gives the driver, not the overall power and torque that the engine can make
  • Like 2
