GUN-808 Member 251 Member For: 11y 8m 3d Gender: Male Location: Gold Coast Posted 09/06/15 05:37 AM Share Posted 09/06/15 05:37 AM Just a question before I waste money on a dyno session and max out my pump..Anyone know a good ballpark that sees the 044/surge max out on e85 ?? and whats the most u have seen ??Currently at 385kw on 98 and about to do an e85 tune for some occasional drags/track work..Iv done a few small tricks to increase flow like different drop in reg with bigger return, drilled out factory cradle etc..Its comfortable atm but think its going to really struggle when on 85.. :/Ill eventually upgrade to a Holley 1400.. But with that comes more $$ of re-tuning my pump tunes, adjustable reg and maybe rail etc.. which I dont really want to have to do..Pretty sure im not going to recieve the advice I want to hear lol but seeing if someone can give me some results cheers 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 12d Gender: Male Location: Adelaide Posted 09/06/15 06:06 AM Share Posted 09/06/15 06:06 AM All depends on what target lambda your tuners uses Nizzy take them to high 400's Others don't like them past 400 Ask your tuner Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548121 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 8m 3d Gender: Male Location: Gold Coast Posted 09/06/15 07:18 AM Author Share Posted 09/06/15 07:18 AM (edited) No worries ta.. im assuming your talking hp here mate ?id like 450kw/600hp so ill see what they reckon before I book it in.. if Hp im definately looking at a new pump then..just read in search that the 2 x 044 goes about 640kw Edited 09/06/15 07:22 AM by GUN-808 Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548124 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 11m 7d Gender: Male Location: Adelaide Posted 09/06/15 07:40 AM Share Posted 09/06/15 07:40 AM Bellends is from sa. We only use kw. Lol Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548125 Share on other sites More sharing options...
stubbietubbie Filthy weeb Member 1,870 Member For: 12y 4m 27d Gender: Male Posted 09/06/15 08:28 AM Share Posted 09/06/15 08:28 AM 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548132 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 16d Gender: Male Location: @ my laptop Posted 09/06/15 09:13 AM Share Posted 09/06/15 09:13 AM the mods you have done do not help with getting more flow 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548137 Share on other sites More sharing options...
sct911 Member 848 Member For: 12y 8m 7d Gender: Male Posted 09/06/15 09:34 AM Share Posted 09/06/15 09:34 AM I only have one 044 at the plazmaman surge tank , and the car has gone 470rwkw on E70, 10.52@ 135.76mph 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548140 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 8m 3d Gender: Male Location: Gold Coast Posted 09/06/15 11:39 AM Author Share Posted 09/06/15 11:39 AM that's what I wanna hear sct And I thought the kw v hp was an age thing not state by state.. lolAnd ratter mate u have a hell of a lot more experience than me so ill take most things u say on board BUT ??with the reg mod your return is only as good as the size of the return line/hole in the reg.. doubling its size with what I replaced has allowed us to lower the base FP a heap and it definately flows a lot more than the stock unit.. so the more fuel that's getting thru that hole and back to the surgie is preventing the surge from drying up under power yeah ?? hence giving the 044/surge I have with this mod a bit more poke before it runs out of pump ?? sorry if im wrong but I thought it was a worthwhile mode for what I wanted to achieve and give me that little bit extra out of the single 044.. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548163 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 16d Gender: Male Location: @ my laptop Posted 10/06/15 12:36 AM Share Posted 10/06/15 12:36 AM what did you actually drill in the cradle?Reg fuel flow issue is only a low rpm thing, does not help with higher rpm at all 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548209 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 8m 3d Gender: Male Location: Gold Coast Posted 10/06/15 09:33 AM Author Share Posted 10/06/15 09:33 AM well the inlet elbow widened out to as far as I could whilst retaining enough for a hose to still clamp to it..and something else in the bottom of the cradle too I remember..but it was more about the reg I believe is the big deal..more fuel (like at least 30%) returning to the surge with the bigger hole..even if theres a tiny bit more going back to the tank..its more the flow volume that's being returned from the reg to the surge.. if the stock pump can flow 300kw at the injectors im sure its more than capable of filling a 2L surgie and keeping that full and the 044 flowing a heap from that point on..im not going to add their flow rates together but I reckon together they can keep up with a fair bit of demand from the 1000s.. and again whats not being used is also being returned to surge to keep that volume up.. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90657-max-power-from-single-044surge-on-e85/#findComment-1548271 Share on other sites More sharing options...
