Rockatansky Member 591 Member For: 16y 5m 12d Gender: Male Posted 11/07/18 01:00 PM Posted 11/07/18 01:00 PM What's the current recommended spark plug gang?
k31th less WHY; more WOT Site Developer 30,104 Member For: 18y 5m 13d Gender: Male Location: Melbourne Posted 11/07/18 01:07 PM Posted 11/07/18 01:07 PM depends on what your setup is etc. just get ford ones if you're stock. if you're keen, go for BKR6EIX
arronm Dropping a turd Legacy Donating Member 9,520 Member For: 18y 10m 27d Gender: Male Location: Perth Posted 11/07/18 01:14 PM Posted 11/07/18 01:14 PM You mean if your cashed up. Even I dont waste $25 per plug. $60 a set is fine.
k31th less WHY; more WOT Site Developer 30,104 Member For: 18y 5m 13d Gender: Male Location: Melbourne Posted 11/07/18 01:17 PM Posted 11/07/18 01:17 PM lollll as if bro, you spend $250 on gold plated ones, for sure.
HI PSI Member 1,589 Member For: 20y 3m 29d Gender: Male Location: Central Queensland Posted 15/07/18 03:13 PM Posted 15/07/18 03:13 PM Just keep in mind that the higher the boost level, the colder the plug...
Slowxr6t Member 593 Member For: 7y 9m 19d Location: New zealand Posted 22/07/19 08:46 AM Posted 22/07/19 08:46 AM What number heat range is stock spark plugs in fg and if I'm going to run 18psi and 350ish rwkw should I run 1 heat range colder? What number would that be? Do fg xr6t have platinum stock?
camo86T Legacy Donating Member 1,810 Member For: 12y 7m 10d Gender: Male Location: SW Sydney Posted 22/07/19 09:07 AM Posted 22/07/19 09:07 AM (edited) See post 27 further up the page Edit For what to run at that level boost Edited 22/07/19 09:08 AM by camo86T
