GAS41T Member 39 Member For: 8y 8m 1d Posted 21/01/18 03:43 AM Share Posted 21/01/18 03:43 AM My worry is the two bolts that back out of the turbo one I could tighten but there is one under the oil feed line where it bolts on to the turbo that’s still easy an inch backed out I’ll have to put lock tight or something on them ....... so do you know what I mean by the bolts that bolts the rear housing the the centre ?? I about to change injectors and dyno tune it but I’m glad I’ve come across this before hand thanks for quick reply Keith Rossko Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,318 Member For: 16y 20d Gender: Male Location: Melbourne Posted 21/01/18 03:46 AM Share Posted 21/01/18 03:46 AM Yes, it's common. And yes, that bolt is difficult to get to, to tighten it appropriately. Try attacking it from underneath with a wobble joint on an socket extension. Link to comment Share on other sites More sharing options...
demon1300 Member 435 Member For: 12y 2m 21d Gender: Male Posted 23/01/18 12:39 PM Share Posted 23/01/18 12:39 PM Yeah I've had bolts fall out of mine and they're a PITA when they do. Don't let them get that far. I've since had the holes drilled and helicoiled as some were cracked, hence the constant loosening.Pays to check them regularly Link to comment Share on other sites More sharing options...
Bottom Pusher New Member 9 Member For: 5y 8m 7d Posted 25/08/18 06:51 AM Share Posted 25/08/18 06:51 AM Every car on the market will have fault s . Buy a car built on a Monday 1 Link to comment Share on other sites More sharing options...
ba6turbo Donating Members 13 Member For: 11y 6m 18d Gender: Male Location: mt isa Posted 26/08/18 09:13 AM Share Posted 26/08/18 09:13 AM 2011 fg xr6t manual ute 70,000klms microswitch under brake pedal replaced, worked 50% of the time fuel level sender died, new in tank pump assembly required clutch slave cylinder died, inside of bell housing tried to get spare key programmed, instrument cluster died ( I <3 Bananas expensive spare key very rare problem apparently) upper control arm bushes died, K-mac kit installed tray lid locking mechanism broke gear shift boot currently falling apart both internal door levers broke windscreen washer bottle motor died brief rattle on top of engine on cold start (hopefully this is a timing chain tensioner problem, all timing gear will be replaced with atomic products shortly) thermostat seal died I think that's about it Link to comment Share on other sites More sharing options...
adams355 Member 529 Member For: 6y 11m 29d Gender: Male Location: Brisbane Posted 26/08/18 09:30 AM Share Posted 26/08/18 09:30 AM You can just replace the fuel sender, won't need new pump assembly. Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 30d Gender: Male Location: WA, Perth Posted 27/08/18 04:54 AM Share Posted 27/08/18 04:54 AM I agree with adam on the sender. ford replaced mine under warranty at the time. Recently got my 2011 FG Xr6T manual sorted with the suspension. Control arms were replaced too. Then again the car does have 104k on the clock. My driver side door leaver fell apart in my hands. I simply took out the door panel and broke the welds. replaced the handle and put screens in place of the welds. Car is going in this week for a new clutch, but that is due to the extra power the car has. 500 ponies at the wheels is not stock power. Link to comment Share on other sites More sharing options...
ba6turbo Donating Members 13 Member For: 11y 6m 18d Gender: Male Location: mt isa Posted 27/08/18 08:30 AM Share Posted 27/08/18 08:30 AM 23 hours ago, ba6turbo said: 2011 fg xr6t manual ute 70,000klms microswitch under brake pedal replaced, worked 50% of the time fuel level sender died, new in tank pump assembly required clutch slave cylinder died, inside of bell housing tried to get spare key programmed, instrument cluster died ( I <3 Bananas expensive spare key very rare problem apparently) upper control arm bushes died, K-mac kit installed tray lid locking mechanism broke gear shift boot currently falling apart both internal door levers broke windscreen washer bottle motor died brief rattle on top of engine on cold start (hopefully this is a timing chain tensioner problem, all timing gear will be replaced with atomic products shortly) thermostat seal died I think that's about it almost forgot the interior head liner dropped, both on my BA and FG 1 Link to comment Share on other sites More sharing options...
espoig Donating Members 249 Member For: 9y 7m 25d Gender: Male Location: Mundaring Posted 27/08/18 10:04 AM Share Posted 27/08/18 10:04 AM Yep, hood liners spend more time hanging than they do on the roof Link to comment Share on other sites More sharing options...
Bottom Pusher New Member 9 Member For: 5y 8m 7d Posted 28/08/18 03:46 AM Share Posted 28/08/18 03:46 AM Pretty common.. wonder if that's covered by warrenty Link to comment Share on other sites More sharing options...
