Tom Tucker Legacy Donating Member 711 Member For: 7y 2m 21d Posted 21/03/22 09:31 PM Posted 21/03/22 09:31 PM This will give you an idea. These are the CVs you want https://www.cartel-aus.com/product/driveshaft-shop-ford-2008-falcon-1400hp-full-chromoly-level-5-axle-hub-kit-supercharged-v8-and-turbo-6/ Nearly $4k just for those. They require a bit of work to fit as well. Even if you go for the ones below this (rated to 700hp), you're still looking at over $3k. IMS diff hat requires quite a bit of work too. It all adds up...
Slowxr6t Member 593 Member For: 7y 9m 17d Location: New zealand Posted 10/04/22 01:52 AM Posted 10/04/22 01:52 AM Get oversize washers for your arp headstuds 1
Don Kedick New Member 16 Member For: 4y 6m 25d Posted 10/04/22 10:54 AM Author Posted 10/04/22 10:54 AM Good Idea, I might get the Atomic head studs instead as they come with oversized washers. Picking up all of my engine parts from Goleby’s tomorrow hopefully so good timing! I just assumed the ARP studs came with oversized washers lucky you said something! Cheers @Slowxr6t
Puffwagon Legacy Donating Member 16,348 Member For: 11y 7m 22d Gender: Not Telling Posted 10/04/22 11:16 AM Posted 10/04/22 11:16 AM The ARP studs do come with washers, but they are smaller than stock washers.
Slowxr6t Member 593 Member For: 7y 9m 17d Location: New zealand Posted 11/04/22 03:29 AM Posted 11/04/22 03:29 AM @Don KedickI used the atomic studs with os washers on my car also. Seemed like a clever idea to stop them washers pulling down into the head alloy.
Puffwagon Legacy Donating Member 16,348 Member For: 11y 7m 22d Gender: Not Telling Posted 11/04/22 06:47 AM Posted 11/04/22 06:47 AM Hp junkie make an os washer as well.
Don Kedick New Member 16 Member For: 4y 6m 25d Posted 13/04/22 11:55 AM Author Posted 13/04/22 11:55 AM Has anyone used an Antz Stage 2 Intercooler? Seems to be pretty good results reported and it is cheap..
