LazyBrennan Legacy Donating Member 683 Member For: 15y 5m 25d Gender: Male Location: Baldivis, Wait Ages. Posted 24/05/18 01:33 PM Posted 24/05/18 01:33 PM Ok guys I am all out of ideas what to check. I am loosing a lot of boost. Should be getting 22 psi and only getting 11 psi. The car idles like an absolute pig and stalls. Little issues are noticed like cruise control for example, I cant actually increase speed. All things point towards a leak somewhere. We have done a compression test and leak down test on the motor and results were all good, We made a device to hook up to the intake and pumped about 30 psi through the whole system trying to hear for a leak and nothing. PCV was checked, Intake manifold gasket was all good (still fairly new and we did pull it apart to check) The actuator has been checked, Throttle body is clean and gasket fine too. Gaskets have been replaced on the turbo. I have tried using a flammable spray like brake cleaner ect around fittings to listen for a change in idle revs and nothing. Also getting the P1131 error engine light code. This engine light comes on at just normal driving speeds. I am sure there is things we have checked and I've for gotten to mention. I am completely stumped as to what else it could be. Any ideas of things to have a look at would be a massive help.
k31th less WHY; more WOT Site Developer 30,097 Member For: 18y 5m 5d Gender: Male Location: Melbourne Posted 24/05/18 01:36 PM Posted 24/05/18 01:36 PM coils? maybe a coil driver from the PCM?
Puffwagon Legacy Donating Member 16,348 Member For: 11y 7m 17d Gender: Not Telling Posted 24/05/18 01:40 PM Posted 24/05/18 01:40 PM Failed cat converter?
LazyBrennan Legacy Donating Member 683 Member For: 15y 5m 25d Gender: Male Location: Baldivis, Wait Ages. Posted 24/05/18 01:54 PM Author Posted 24/05/18 01:54 PM Cats been gutted. 15 minutes ago, k31th said: coils? maybe a coil driver from the PCM? Would I still be able to get desired fuel though if that was the case? Was roll racing the other night only getting about 11-12 pounds of boost but my lambda gauge was showing a nice 0.82 the whole time.
k31th less WHY; more WOT Site Developer 30,097 Member For: 18y 5m 5d Gender: Male Location: Melbourne Posted 24/05/18 02:02 PM Posted 24/05/18 02:02 PM so it actually goes alright when you're up it? e.g only idles and cruises badly? I wouldn't trust an AFR gauge unless you've installed a separate wideband, which I assume you've done, so that doesn't matter anyway.
LazyBrennan Legacy Donating Member 683 Member For: 15y 5m 25d Gender: Male Location: Baldivis, Wait Ages. Posted 24/05/18 02:07 PM Author Posted 24/05/18 02:07 PM Well it goes alright for 11 pounds of boost but it should be getting 22. The AFR gauge is a PLX one with a separate 02 sensor installed for it. Its about 2 months old.
k31th less WHY; more WOT Site Developer 30,097 Member For: 18y 5m 5d Gender: Male Location: Melbourne Posted 24/05/18 02:36 PM Posted 24/05/18 02:36 PM I'd still be checking the coils and wiring to the coils as a first step from here...
Rab WOT? Legacy Donating Member 10,981 Member For: 13y 6m 21d Gender: Male Location: Frankston, 3199 Posted 24/05/18 02:38 PM Posted 24/05/18 02:38 PM Is this the 10sec car?
LazyBrennan Legacy Donating Member 683 Member For: 15y 5m 25d Gender: Male Location: Baldivis, Wait Ages. Posted 24/05/18 02:40 PM Author Posted 24/05/18 02:40 PM Yup 3 minutes ago, k31th said: I'd still be checking the coils and wiring to the coils as a first step from here... Ill have a look
arronm Dropping a turd Legacy Donating Member 9,520 Member For: 18y 10m 19d Gender: Male Location: Perth Posted 24/05/18 03:42 PM Posted 24/05/18 03:42 PM Have you checked the turbo. Sounds like your not leaking boost, the car just isn't making 22psi. What does your tuner think.
