MattyP MattyP Legacy Donating Member 6,317 Member For: 14y 4m 21d Gender: Male Location: Central Coast Posted 29/10/14 12:11 PM Posted 29/10/14 12:11 PM But more capable if you look at the data. However with the same evidence you and I have we come to different conclusions.I won't be changing my mind on the 044 in its current state unless it's improved. Noise for me is an issue. Although all the road noise and exhaust noise would drown it easily. Which reminds me I should fix that. And I've seen an 044 do that. It's a risk we all run.It kind of reminds me of the everything's ok alarm homer made
luke187 Member 297 Member For: 12y 9m 18d Posted 29/10/14 12:15 PM Posted 29/10/14 12:15 PM Luke those surge tanks are pure junk on ebaySuper thin walled, very prone to leaking ( seen a few now ) and this is just the startSurge tanks need to be correctly baffled internally and this is just the start of it, the plaz and pw undercar surge tanks are ok value for money when u look at the quality and finish then backed up with the quickest and highest power turbo falcons in the country and countless other vehicles over the past decadeProven product for reasonable coin to suit nearly any fuel demanding situationFair enough. I guess for me new to the ford scene I was just blown away by the prices of things. Surge tanks, airboxes, interoolers, forged motors etc.. Nobody wants junk on their car especially when I comes to fuel systems but theres gotta be a middle road somewhere 1
MattyP MattyP Legacy Donating Member 6,317 Member For: 14y 4m 21d Gender: Male Location: Central Coast Posted 29/10/14 12:16 PM Posted 29/10/14 12:16 PM I was exactly the same mate.You can't do it on the cheap But you can do it on a budget
k31th less WHY; more WOT Site Developer 30,106 Member For: 18y 5m 15d Gender: Male Location: Melbourne Posted 29/10/14 12:19 PM Posted 29/10/14 12:19 PM Cheap is just a comparative term. They aren't the cheapest pump available - but they are proven to be a very good quality pump (if you buy genuine) time and time again. Noisy - yes, when mounted badly - when mounted correctly there's bugger all noise. 1
luke187 Member 297 Member For: 12y 9m 18d Posted 29/10/14 12:23 PM Posted 29/10/14 12:23 PM True that. Serious question though, if I can buy off the shelf or custom made units for other cars for $3,4,500 whats up with falcon ones costing $11,12,1300? Is it a case of cornered market, falcons having an unsuaually high demand for heavily engineered fuel systems, or something else?
k31th less WHY; more WOT Site Developer 30,106 Member For: 18y 5m 15d Gender: Male Location: Melbourne Posted 29/10/14 12:31 PM Posted 29/10/14 12:31 PM low production volumes.
KPM Motorsport Member 968 Member For: 20y 11m 3d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 29/10/14 10:48 PM Posted 29/10/14 10:48 PM (edited) Explain????How can an intank make more power than a surge???Surge tanks inherantly heat the fuel quicker and at a much more aggressive non-linear rate than an intank system.Especially on forced induction Turbo cars , we find that the more under bonnet heat and exhaust temp generated by extra boost and load the quicker the fuel temperature spikes.This is due to surge tanks continously recirculating the heated fuel rail fuel back to approx only 2 litres of surge tank resevoir capacity and then re-using it again back to the rail. We call this superheating the fuel.On intank systems the fuel is returned back to the swirl pot , however this time is mixed with fresh scavenged fuel at approximately a 1:1 ratio.Also Intank system are generally surrounded by at least 10 litres of fuel onwards ( depending on how much you have in the tank) . This means that the heated return fuel from the rail is returned to a much larger volume of fuel . Clunky analogy:Add 1 litre of hot water to 2 litres of cool water.versusadd 1 litre of hot water to 10 litres of cool waterThe hotter the fuel , the less energy it has to make powerThe hotter the fuel , the more prone it is to boiling , aeartion and surgeThe hotter the fuel the less cooling effect it has on intake temperatures meaning less ability to add maximum timing and boostThe hotter the fuel , the less grunt.In short fuel boils at approx 25 deg c at atmospheric pressure and appox 60-65 deg c at 400 kpa rail pressure.We aim to keep as far away from these temps as possible. Edited 29/10/14 10:49 PM by KPM Motorsport
rollex Member 683 Member For: 12y 3m 17d Gender: Male Location: Australia Posted 29/10/14 11:13 PM Author Posted 29/10/14 11:13 PM Surely there are surge tanks on the market with the return line going to the main tank making that point moot?
rednose RNS10S Legacy Donating Member 2,229 Member For: 20y 1m 9d Gender: Male Posted 29/10/14 11:19 PM Posted 29/10/14 11:19 PM Surge tanks inherantly heat the fuel quicker and at a much more aggressive non-linear rate than an intank system.Especially on forced induction Turbo cars , we find that the more under bonnet heat and exhaust temp generated by extra boost and load the quicker the fuel temperature spikes.This is due to surge tanks continously recirculating the heated fuel rail fuel back to approx only 2 litres of surge tank resevoir capacity and then re-using it again back to the rail. We call this superheating the fuel.On intank systems the fuel is returned back to the swirl pot , however this time is mixed with fresh scavenged fuel at approximately a 1:1 ratio.Also Intank system are generally surrounded by at least 10 litres of fuel onwards ( depending on how much you have in the tank) . This means that the heated return fuel from the rail is returned to a much larger volume of fuel . Clunky analogy:Add 1 litre of hot water to 2 litres of cool water.versusadd 1 litre of hot water to 10 litres of cool waterThe hotter the fuel , the less energy it has to make powerThe hotter the fuel , the more prone it is to boiling , aeartion and surgeThe hotter the fuel the less cooling effect it has on intake temperatures meaning less ability to add maximum timing and boostThe hotter the fuel , the less grunt.In short fuel boils at approx 25 deg c at atmospheric pressure and appox 60-65 deg c at 400 kpa rail pressure.We aim to keep as far away from these temps as possible.You're obviously aware of the setup I have and are following the thread on AFF.I would like to see similar tests that I am doing with one of your intank setups, not pouring hot water into cold water.You fail to mention that the surge tank is made of alluminium (not plastic) and ambiemt air temp flows past it and helps cool it.I do not think I would benefit from a KPM intank, not saying it doesn't work, just saying I can't see the need to upgrade.
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 25d Gender: Male Location: Adelaide Posted 29/10/14 11:23 PM Posted 29/10/14 11:23 PM KPM george has made the effort to supply fuel temps/volumes/time/distances on AFFWheres your data in this very simple test ?You have claimed to do every test under the sun but wheres these stats ? You say surge tanks are "boiling" the fuel but georges stats are no where boiling and also seen once a temp is maintained and cool bowser fuel added the temp didnt "cool" the existing tank fuel where id say your basis to you claims lieCan u supply these basic stats so we can cut the B/S on writing off one product but not another 1
