KPM Motorsport Member 968 Member For: 20y 11m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 19/09/14 05:10 AM Posted 19/09/14 05:10 AM KPM are proud to announce our exclusive 10,000 Hour rated E85/Ethanol/ Petrol compatible fuel pump. This means approximately 10 years continuous usage on straight E85/Ethanol/Petrol fuel. Over the years we have seen many E85/Ethanol compatible pumps fail due to the installer and or consumer not realising that they are only rated to limited hours of usage.These pumps are often classified as E85/Ethanol compatible, however with limited life span. With the abrasive nature of E85/Ethanol we generally see that they are rated at approximately 500 hours of continuous usage. The KPM300 fuel pump has been manufactured to comply with 10,000 hours of stringent tests and maintains its performance after 1000hrs on abrasive corrosive sulfur fluid.The KPM300 fuel pump is a direct replacement upgrade to many standard pumps as well as being suited to E85/Ethanol retrofits, high performance in-tank and surge tank systems.- E85/Ethanol/ Petrol compatible for 10,000 Hours continuous use!- 300 litres per hour flow capacity- 38mm universal and compact design- Extremely quiet operation- Perfect upgrade replacement on many Australian OEM systems- Overnight freight Australia WideDirect Order
kyle173 Legacy Donating Member 774 Member For: 17y 10m 21d Gender: Male Location: brisbane Posted 19/09/14 05:40 AM Posted 19/09/14 05:40 AM price?
rednose RNS10S Legacy Donating Member 2,229 Member For: 20y 1m 7d Gender: Male Posted 19/09/14 06:44 AM Posted 19/09/14 06:44 AM (edited) How do you get the 10,000 hr rating???Did you guys have one flowing e85 for 417 days non stop??? The KPM300 fuel pump has been manufactured to comply with 10,000 hours of stringent tests and maintains its performance after 1000hrs on abrasive corrosive sulfur fluidAnd is it 10,000 or 1000??? Edited 19/09/14 06:44 AM by rednose 2
KPM Motorsport Member 968 Member For: 20y 11m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 19/09/14 10:52 PM Author Posted 19/09/14 10:52 PM How do you get the 10,000 hr rating???Did you guys have one flowing e85 for 417 days non stop???CorrectAnd is it 10,000 or 1000???10,000 hours on e85 / 1000 hours on abrasive corrosive sulfur test fluid 2
Robos F6 Legacy Donating Member 407 Member For: 17y 6m 21d Gender: Male Location: Vic Posted 20/09/14 12:30 AM Posted 20/09/14 12:30 AM What kind of rwkw will it achieve?
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 13y 1m 17d Gender: Male Location: Adelaide Posted 20/09/14 02:52 AM Posted 20/09/14 02:52 AM price
julesk_1972 Member 267 Member For: 14y 1m 29d Gender: Male Location: Perth Posted 20/09/14 03:23 AM Posted 20/09/14 03:23 AM Silence with the price question is becoming scary.....
Seaton Legacy Donating Member 537 Member For: 14y 27d Gender: Male Location: Sydney Posted 20/09/14 10:05 AM Posted 20/09/14 10:05 AM They are priced at $159.
KPM Motorsport Member 968 Member For: 20y 11m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 21/09/14 11:35 PM Author Posted 21/09/14 11:35 PM Silence with the price question is becoming scary.....Sorry.$159 eaSupport Approx400 rwkw N/A300 rwkw Forced Induction 1
.Stripes. All stock bar the k&n panel filter Legacy Donating Member 8,061 Member For: 14y 6m 10d Gender: Male Location: Perth Posted 22/09/14 12:10 AM Posted 22/09/14 12:10 AM 300rwkw on E85 for forced induction motors...I am the only one that doesn't see the point in that? That's essentially stock car power levels on E85...Can two of them be used like with your twin 1000hp setup?
