Engine Reseal Project
Featured Replies
#1
Hey guy,
I've been putting this off for a while now but it's time to fix my to fix all my leaks.
My engine had a mishap when the PCV one way valve started to fail and pressurize the crank case. Since fixing the PCV, I've have acumulated a few annoying leaks and my head gasket has started to leak coolant :)
The list:
*head gasket
*rocker cover
*timing cover
*sump
*rear main
*engine mounts
*valve springs
post-49516-0-89270200-1409006761_thumb.j
post-49516-0-75031400-1409006792_thumb.j
  • Replies 25
  • Views 3.2k
Most Popular Posts
  • Correct, ended up buying that socket set, did the trick It appears I've joined the broken chain guide club. The chain was holding the guide together, I had no idea. Supreme engine mounts:
  • I would do all the core plugs at the same time. Use stainless steel plugs A stock Ford MLS with no sealer will not fix anything. MLS really need a sealer IMO. You said you are going to use Hylomar whi
Posted Images
#2
  • Author
Does anyone know what size e-torx socket is required for the head bolts? I have to run out at lunch and buy a set :P
#3
I use a normal multipoint socket
#5
for what its worth, I would buy the e-torx sockets, think of it, 30 bucks and there yours, they come in handy a sh*t loads of time, my mate brought a set of them, now I want them!! haha
also allot of the sockets at supercrappo have a life time warrenty, except the elcheapo ones for 2 bucks haha. I have put a few through hell and never broke one yet. Not saying you cannot break them though lol
#6
From memory an e-18 etorx socket
#7
  • Author
Correct, ended up buying that socket set, did the trick :)
post-49516-0-76110500-1409097257_thumb.j
post-49516-0-75551400-1409097392_thumb.j
#9
  • Author
130,000km
First 75,000 it lived in Brisbane and got dealer serviced before I bought it, now lives in the country and gets flogged but more regular servicing.
The contrast between lifestyles highlighted the varnished up check valve on the PCV system about 2 weeks after I bought it, making most of the seals leak :(
Dropped the head in for machining/inspecting this morning. They are also going to install the new plazmaman valve springs :)
Stripped
post-49516-0-87282300-1409180557_thumb.j
Bore still tidy
post-49516-0-62414900-1409180130_thumb.j
Rear right corner where the leak was most prominent
post-49516-0-93974000-1409180145_thumb.j
Edited by timwds
#10
Might be a silly question but I'm a noob so IDGAF. Is the black piston top crud only due to coolant getting in to the combustion chamber?
Recently Browsing 0
