  • MattyP
  • Legacy Donating Member
  • Member For: 14y 4m 13d
Posted
E85
Pre turbo water injection
Billet wheel
Pick any of those 3 to get more from the standard turbo
  • Member For: 12y 1m 21d
Posted (edited)
My mate in his fg small turbo made 327rwkw tuner said that's Maxed out this is with injectors,cooler, dump pipe, cat and intake so that ballpark figure seems about right :) also as we all know dyno figures vary so the 327 on that particular dyno may be slightly less on another.
Edited by Cjafpv
  • I'm getten too old for this s**t
  • Member For: 13y 5m 10d
Posted
I am wondering, how much extra can it make if you push it from say 15/16 PSI that most cars are tuned to, to about 20, 22 PSI?
On 15 - I've got 319 and I asked Pit Lane to delete an 18psi tune coz it dropped power to 310 or something and the old girl couldn't hold 18 very well at all.
Dyno showed it hit 18 really quickly but then dropped away almost as quickly. A good tyre shredder tune but not practical (for me).
My guess is that anything higher than 18psi would follow along the same lines and the baby snail would probably struggle to give 300. The poor thing will just run out of puff.
  • Member For: 13y 8m 15d
Posted
Mine ran out at 13psi couldn't get anymore but held it all for the whole run just got 300rwkw have all supporting mods for big power now saving for the 6235
  • Member For: 15y 10m 26d
Posted
Highest I've seen was Stainos 327 tuned at Pitlane, but had all the supporting mods to make that power.
  • Member For: 20y 3m 21d
Posted
changing the compressor wheel means it's not the stock baby turbo anymore, that's where it gets hard when records are claimed, different interpretations come into play
  • Member For: 22y 1m 26d
Posted
I maxed out at 322rwkw on mine at 13psi.
Once you switch to a bigger turbo you realise how limited the lttle turbo is.
Now using a pt6235 400rwkw at 17psi.
  • RNS10S
  • Member For: 20y 1m 1d
Posted
I've seen 357 from a zf equipped stock FG turbo tuned on E85.
Car went on to run a 10.8 @ 125
