gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 8d Posted 14/10/14 10:05 AM Share Posted 14/10/14 10:05 AM (edited) The change is now mixing 98 with ethanol not 91. So does it need to be touched up, probably not, can u squeeze a little more, yes. Edited 14/10/14 10:05 AM by gaz097 1 Link to comment Share on other sites More sharing options...
Rydeit Member 327 Member For: 11y 9m 18d Gender: Male Location: Adelaide S.A Posted 14/10/14 10:17 AM Share Posted 14/10/14 10:17 AM No need for touch up. In SA we have the race blend. Tuner says didnt need a retune. Runs fine. 1 Link to comment Share on other sites More sharing options...
RynoF6 Idiot Member Donating Members 446 Member For: 14y 3m 7d Gender: Male Location: Muswellbrook, NSW Posted 21/10/14 01:13 PM Share Posted 21/10/14 01:13 PM Im tuned on eflex but its a 80km round trip to the nearest. Car doesnt get driven much but united e85 is a lot more readily available to me(10km from home). I have been using e85 from united and mixing it down to eflex content with 98 for the good part of a year. In jerry cans with m2 lube added. Even made a trip from Newcastle to Brisbane mixing it down. United e85 avail the whole way up new england hwy.I do need a United e85 tune though. Link to comment Share on other sites More sharing options...
G6ETNZ Member 82 Member For: 10y 6m 12d Gender: Male Location: Auckland, NZ Posted 18/05/15 05:52 AM Share Posted 18/05/15 05:52 AM Had a read and a search, is there any advantage/disadvantage to running E85 in a stock car? Curious to try a tank if there is a gain. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 17y 11m 1d Gender: Male Location: @ my laptop Posted 18/05/15 06:05 AM Share Posted 18/05/15 06:05 AM Stock, you need a tune at least, but then fuel system would be maxed before any real benefit is taken advantage of Link to comment Share on other sites More sharing options...
G6ETNZ Member 82 Member For: 10y 6m 12d Gender: Male Location: Auckland, NZ Posted 18/05/15 06:40 AM Share Posted 18/05/15 06:40 AM Stock, you need a tune at least, but then fuel system would be maxed before any real benefit is taken advantage ofThanks, appreciate the reply. 1 Link to comment Share on other sites More sharing options...
nathanway Member 106 Member For: 12y 8m 22d Gender: Male Location: townsville Posted 06/06/15 07:25 AM Share Posted 06/06/15 07:25 AM (edited) thinking about tuning my car on e85have a few questionshow to get it from the barrel to my carie a rotary pump or electric pump? were to buypeoples experience with 1000cc injectors and were they'll run outwere to buy a tester to ensure its e85 not higher or lowerwere to buy e100 from to mix in off neededand what other people are doing with there setups.planning to do trips to Moranbah from Townsville 2 or 3 barrels at a time as I have family theremods listgtx 35 with soon to be installed xr6turbo developments 45mm external gated rear housingtbre stage one cams (tbre wont tell the numbers but aparantly its similar to atomic stage 4)plasmaman surge and twin 044s with new fuel reg1000cc idsnizpro built zf hardie built tale shaft stock converter upgraded dif cradleatomic oil pump4inch exhaustrapid cooler /air boxmt 275shoping for about 440ishkw with e85and easy into the 10sheading to power cruise this year in sep just trying to sort out all the bugs and get her running sweet asap Edited 06/06/15 07:37 AM by nathanway Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 17y 8m 12d Gender: Male Posted 03/07/15 02:38 AM Share Posted 03/07/15 02:38 AM Probably best to read through the thread from the start, you'll find answers to most of your questions in here. Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 16d Gender: Male Location: SW Sydney Posted 06/11/15 04:04 AM Share Posted 06/11/15 04:04 AM (edited) Anybody else using this? http://www.nulon.com.au/products/Fuel_Treatments/E85_Performance_Fuel_TreatmentDid a search of this thread in particular and the whole fuel system section but no hitsBought a bottle todayKnowledgeable opinions pls...does what it says? So many positives if so Edited 06/11/15 04:05 AM by camo86T Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 06/11/15 04:10 AM Share Posted 06/11/15 04:10 AM Got a few gifts from the nulon rep but haven't used it yet Link to comment Share on other sites More sharing options...
