  • ...JD TUNING ADELAIDE...
  • Legacy Donating Member
  • Member For: 18y 3m 21d
Posted
It pivots and lifts off from flush aprox 19mm at the highest mechanically but its all relevant to commanded D/C and at full rpm its usually back to the "seated" position to command full flow across the rear wheel
  • Dropping a turd
  • Member For: 18y 10m 25d
Posted
With a user name like that it sounds like you have already had a "PORT" job.......
Posted
Could be worse
Could have the same name as u but spelt correctly ;)
  • Carnage on the Garage Floor
  • Member For: 16y 4m 10d
Posted
seated at full rpm?
  • 10 months later...
  • less WHY; more WOT
  • Site Developer
  • Member For: 18y 5m 11d
Posted (edited)
that'll get you the nuts, but you would want different studs...
The studs are M10x1.25 on one side and M10x1.5 on the other. The 1.5 end goes into the manifold and the 1.25 allows for a finer thread and more torque on the turbo side.
EDIT: these ->
http://www.ebay.com.au/itm/TURBO-EXHAUST-STUD-NUT-SET-M10-X-1-25-M10-X-1-5-4-PACK-/151390627050
with either stage 8 fasteners -> http://gcg.com.au/turbo-parts/stage-8-fasteners/stage-8-fasteners-m10x1-25-nut-lock-kit-detail
or nordloc washers. -> http://www.ebay.com.au/itm/1-Stuck-NORD-LOCK-NL10-Keilsicherungsscheiben-M10-Sicherungsscheibe-NordLock-/151257003664
Edited by k31th
