  • Legacy Donating Member
  • Member For: 14y 4m 13d
Posted (edited)
Is this correct, (450mls in 15 secs) because the I've got an after market braided line for my BA and it has a restrictor on the turbo end ( approx. 1mm hole ) and I checked the flow with the restrictor and it was about 150mls after 15 secs, and without the restrictor it was bang on 450mls. Do the Earl lines have a restrictor on them and has anyone checked the flow from it,
Im a bit worried to use mine after reading this ^. I might put my old one back on and check the flow before taking the car for a drive with the new one, Cheers
Edited by xr6thsveta
  • Dropping a turd
  • Member For: 18y 10m 21d
Posted
The restrictor is in the turbo, the line doesnt need one. Its 0.8mm, the turbo actually needs very little oil.
Posted
So could that restrictor in the line starve the turbo of oil, I wont be leaving mine in but could others have issues with it by leaving it in ?
Cheers
  • Dropping a turd
Posted
No. Constant size constant pressure , it will flow the same
  • 1 month later...
  • Member For: 17y 11m 18d
Posted
Just a few weeks ago I did mine for the first time @ 241,000 kms before it went for its latest newest tune. It was reasonably clean and I could not visibly see any blockages with a light shone through it. It could have gone back in with a good clean but I bought a new factoey filter and fitted cos its good insurance.
I think it comes down to good routine of oil/filter changes. I have had my car almost since new and I change the oil/filter every 6,000 kms without exceptions. My car has been tuned for about 6 years so far
No fancy oil just valvoline engine armour 15/40
Good service routine goes a long way
  • Like 2
  • Dropping a turd
Posted
The best way to clean the turbo filter. IS TO THROW IT IN THE BIN
  • Like 4
  • Member For: 15y 8m 8d
Posted
That's exactly what I did too arronm, never had any problems! Waste of money doing anything else. Bet hardly anyone with an earls actually cleans them even though they thought they would...
  • Like 2
  • Member For: 12y 9m 28d
Posted
You would have to be real lazy not to, can be done before the oil has finished draining.
Posted
I know but I'd bet a lot of ppl never/rarely do, then does their mechanic even? Maybe if they're a tuna but otherwise prob not.
  • Dropping a turd
Posted
Tuna????
