blacktur8oute Member 139 Member For: 12y 9m 29d Gender: Male Posted 28/07/19 05:57 AM Posted 28/07/19 05:57 AM Hi all im about to install head studs, valve springs and install an atomic oil pump I’ve taken the timing chain cover off and I’m at top dead centre why don’t the yellow links line up at the top of the cams but when reinstalling they must just curious
bamk2f6tornado Legacy Donating Member 777 Member For: 12y 9m 27d Gender: Male Location: Rockhampton Qld Posted 28/07/19 06:45 AM Posted 28/07/19 06:45 AM Yellow links will only line up with the cam marks at tdc once in every 36 crank rotations
blacktur8oute Member 139 Member For: 12y 9m 29d Gender: Male Posted 28/07/19 07:17 AM Author Posted 28/07/19 07:17 AM Thanks for that
arronm Dropping a turd Legacy Donating Member 9,520 Member For: 18y 11m 3d Gender: Male Location: Perth Posted 28/07/19 08:51 AM Posted 28/07/19 08:51 AM As long as the distance between the cam sprockets is correct they dont need to line up exactly. Dont let the chain lose the location on the bottom tone ring. This is close enough.
NA_TURBO Member 532 Member For: 10y 11m 22d Gender: Male Location: Mildura Posted 28/07/19 09:22 AM Posted 28/07/19 09:22 AM Might be helpful
blacktur8oute Member 139 Member For: 12y 9m 29d Gender: Male Posted 29/07/19 02:39 AM Author Posted 29/07/19 02:39 AM Thanks arronm & na turbo 1
blacktur8oute Member 139 Member For: 12y 9m 29d Gender: Male Posted 13/08/19 07:48 AM Author Posted 13/08/19 07:48 AM Just wondering if the bottom end is close enough to TDC it can go slightly to the left but it I do that then the cam sprockets will be out and the chain won’t go on
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 30d Gender: Male Location: Adelaide Posted 13/08/19 11:19 PM Posted 13/08/19 11:19 PM It’s common for all of the timing assembly to sway slightly either right or left but the simplest way of knowing everything is correct is the timing marks on the chain are in direct location to the dimples and lower sprocket markers it literally can’t be wrong if these all align hence the amount of markers you'll also notice the cam phasor sprockets actually sit skew slightly not exactly bang on 12 o’clock mark up top always rotate the assembly by hand many times afterwards to check clearance and give the tensioner ratchet a chance to take up
blacktur8oute Member 139 Member For: 12y 9m 29d Gender: Male Posted 15/08/19 06:34 AM Author Posted 15/08/19 06:34 AM Thanks for the info jet all the timing marks on the chain line up where they should make sense now that the timing assembly may swat to the right or left slightly
