  • MattyP
  • Legacy Donating Member
  • Member For: 14y 4m 20d
Posted
I had the 4inch dump and cat with 3.5 cat back with the totally standard fg turbo.
It smashed 18psi tapering off to around 11.
I was ok with that
  • Member For: 13y 8m 22d
Posted
Hopefully I get the same getting same system wouldn't go past 13 on the first round of mods with just bolt In cat.
  • Dropping a turd
  • Member For: 18y 10m 28d
Posted
Just put a decent cat in it and to save money a redback mild steel twin 2.5. Make 350 easy
  • Member For: 12y 13d
Posted
so you reckon the stock dump is fine at the power level?
  • Dropping a turd
Posted
It would be best to change it. But if your on a budget spend the money on something else. 320KW would be nice budget power level
  • Member For: 11y 10m 5d
Posted
Just picked up my TTG from exhaust shop couple of hours ago. 4 inch dump in stainless going into a 4 inch cat which tappers into a 3.5 into a dual than into the stock 3" system that's been debunged. dead quite when cruising whistling its head off at half throttle anything after that shes over boosting waste gate cant release enough pressure. No torque loss or any other myths iv heard off. Barely touch the throttle and she sits on a 100 and pulls up hills with just a touch more throttle. Im not game enough to WOT as its not tunned yet.
Posted
With my set up guys have pulled 350awkw. You can get easily 500 rwkw on the exact same system but your rods will let go. I got my system cheaper than what I could on ebay so I got stainless wasnt by choice the exhaust shop only does customs in stainless. Exactly what others have said is true, mild in my opinion gives a nicer note. I worked for a reputable exhaust shop for a short while, every tuner I spoke to said to me the same thing also. Your far better off spending on a 3.5 inch dump from ebay or a 4inch dump from an exhaust shop and buying a cheap high flow cat (or knock your one out) than wasting your money on a bling cat back system. Do you wanna be pig bait with sound and no performance or do you wanna be a sleeper that goes hard. Any system apart from stock will help you. But you seem to be on a budget so its up to you what your after. Save your money for some sticky rear tyres. If you read through all the forums there are guys pulling 1000rwkw on a 3.5" all the way. I bet you any money in the world that they couldnt come close to those numbers if they had a stock cat and dump and had the worlds most expensive cat back system. But yet the other way around they wont be far off the mark. Ebay and fitting it yourself will put more dollars into your pocket. Hope this helps.
  • Member For: 12y 2m 29d
Posted
Depends on the tuner with wastegate & flapper mod, some will tune it on the stock turbo others won't tune unless it's done. That's what I found calling around before I did my tune anyway.
Posted
Yeah im not looking to show off or attract cops with a system louder then a rocket. I want a nice tone, don't wanna be the loudest in the room. I definitely want a turbo back system but a lot of people were telling me that 350 awkw is easily achievable with the stock dump. My budget is tight and so far haven't been able to find a system under 1600 or so give or take.
  • MattyP
Posted
Dump and cat
Can be done for around 1g
Still be quiet and you'll pick up spool
