Gasket Between Turbo And Manifold ?
Featured Replies
#1
just wondered if the gasket is necessary at all .only asking due to when I disassembled turbo from manifold there was no gasket .I have purchased a permaseal mls-r turbo gasket kit. is that ok to use or are there better ones ? or just do not fit one at all ?thanks for your help guys
#2
Best to fit one, if for some reason the surface isn't true it will leak, at least fitting a gasket removes this possibly. I used a $30 ebay kit so your should suffice.
#4
I had one fitted 6 months ago and it recently developed a hole in it
It was a cheap one from eBay that was a composite material
I am getting it replaced on Thursday and the turbo specialist doing the work explained that running a gasket is best but to fit a crushable metal gasket so it stays together
  • 3 weeks later...
#6
I just removed a permaseal mls one last weekend as it had shrunk to half its thinckness over 12 months and made my car run rich as sh*t. was also using atomics bolt kit and even they went loose from the peice of crap shrinking. back to no gasket for me for now.
#7
  • Author
fitted mine and the engine is back in the car now . and its such a pain in the ass to take of the turbo .
  • 1 month later...
#8
If they need a gasket why don't they fit one from the factory?
Edited by Dez72
#9
No gasket made thorpie gay.
#10
I find gaskets cause issues, especially with them compressing on the corners and warping stuff and blowing out the gasket where it is not compressed.
Best thing is to have a good machinist machine the turbine housing and the manifold baby bottom smooth if the surfaces have degraded and not true.
I have added hi temp silicone between the surfaces and it does not really do much, but I have heard there is a product/sealant you can use that does not burn off between the matting surfaces but don't know what it is called.
Edited by turbotrana
Recently Browsing 0
