  • Member For: 14y 3m 21d
Posted
Alright mate thanks, will look at chucking that on too... Will the STD diff and tail shaft hold up with this sort of power?
  • Member For: 15y 8m 4d
Posted
I'm no expert but I would expect the wheels to spin before any damage is done if driven properly on non-slicks.
Have had some big thuds changing from one surface to another with the wheels spinning sometimes though.
Posted
Thanks guys you've been a really big help... I'll be chucking these mods on in the next couple weeks...just gotta look into this surge tank, is it really necessary to put it on or is there a good chance something will go wrong if I don't?
  • Legacy Donating Member
  • Member For: 16y 4m 13d
Posted
I'd go a surge tank as well if you can afford it. Always paranoid whether you have enough fuel in the tank otherwise. I would also be going bigger injectors and doing e85 as well.
  • Member For: 15y 9m 3d
Posted
A surge tank will make sure you don't starve the engine of fuel at WOT with less than 1/4 tank of fuel. When you accelerate hard, all the fuel swirls to the back of the tank and the pump can have issues. A Surge tank is insurance against the pump not picking up fuel and starving your engine of fuel.
  • Member For: 14y 10m 21d
Posted
TLB
I have same mods but with ID 1000 injectors, you don't really need a surge tank.
With a reputable tuner you should get 310-330rwkw.
Diff and tail shaft will be fine.
Speak to a few good tuners and you will be amazed with the results.
Cheers
Armando
  • loitering with intent
  • Member For: 23y 1m 3d
Posted
I disagree about not needing a surge tank.
Cheaper than an engine rebuild. Good insurance IMO
I have owned 3 T6s ( sedans) and all needed a surge tank for my piece of mind
over 300rwkw
  • Like 2
Posted
I think I'm gonna chuck one on just to be safe.... Anyone know where I could get one for cheap? They normally around $1000 aren't they?
  • Member For: 16y 11m 11d
Posted
They do seem expensive, But they are tailor made for the XR6T's. Hidden from view, proven to work. Almost plug and play with the wiring kit.
Alot better then a generic surge tank sitting in the boot.
