  • Member For: 20y 4m 9d
Posted
968's would not give you 350 with good afr's, 60's will do the job but not the nicest injector
  • Legacy Donating Member
  • Member For: 15y 9m 25d
Posted
I have ID725's and im happy with them so I can recommend those from experience but they can be pricey. But as stated above you get what you pay for.
I can also from experience not recommend 'drilled' or 'high flowed' injectors, I had a bad experience with these so I will not buy them again.
Also the Injector Dynamic brand injectors they are 3/4 length to suit the FG's.
On another note, Pitlane are trialling a new injector so ive heard which may be even better than the ID's but Mick can elaborate on that.
  • Member For: 15y 10m 7d
Posted
whats so bad about getting injectors re drilled or hiflowed?
  • Member For: 18y 6m 16d
Posted
They end up all over the shop flow wise
  • Member For: 15y 8m 26d
Posted
Tempted to not use the Nizpro ones that came with my stage 2 kit, don't see many people with great things to say about them, or drilled injectors in general.
Posted
Get them flowed and have a look.
  • Member For: 15y 2m 9d
Posted
I had a set of drilled injectors (fg) flow tested... Came up pretty good within 5% but I still would never use drilled injectors
