  • Legacy Donating Member
  • Member For: 17y 1m 22d
Posted
300 on stock injectors, I remember seein ratter post a status sayin he did it on a car, 95 octane as well, BUT he wouldnt recommend it, why would you push the car to such extremes to get that power and get a mass lean out and boom.. then a 3500 exhaust and tune turns into a 5 grand engine rebuild and your no better off for it
  • Member For: 14y 9m 22d
Posted
Did I hear u correctly it's a 03 ba and u are willing to spend over 5k on mods on it how about upgrading the model ! Wow wee
  • Member For: 14y 9m 19d
Posted
Here are the prices as requested.
Supply and fit injectors and custom tune including the flash 3 box - $2195
Supply and fit a full stainless steel exhaust - $2295
Supply and race valve springs - $1595
Remove turbo and supply 12psi actuator and port waste gate hole with 38mm swing valve - $895
Supply and fit high flow fuel pump - $595
Supply and fit under battery air intake system - $645
The price to lower the vehicle can vary depending on options. I recommend a full coil over kit. The cost to supply and fit the coil over kit is $2295. This price also includes a wheel alignment. If you prefer the cheaper option we can just replace the coil springs. The cost to do this is $770, Please o not hesitate to contact me for further information at your convenience.
  • I <3 Floods
  • Member For: 15y 2m 10d
Posted
Most of those prices are pretty good.. But you're paying big time for labour.. I'd be fitting your own injectors and air intake at least.. (Admittedly injectors would need to be done in the carpark of the mechanics..)
  • Moar Powar Babeh
  • Member For: 21y 18d
Posted
MCMERGEATRON ACTIVATE>
Yeah, we aren't going too do this each time you get a quote. Keep it in 1 thread please.
  • Member For: 20y 13d
Posted
600 to supply and fit a fuel pump? Its a 15 min job
  • A much better forum
  • Member For: 18y 2m 18d
Posted
$770 for coil replacement is expensive!!!
  • Here since the start...
  • Member For: 23y 5m 15d
Posted
$770 to supply and fit new springs seems pretty good to me.
How much do you think it should be?
Posted
I paid $240 for springs... And $250 for fitting including wheel alignment.
