  • Legacy Donating Member
  • Member For: 15y 9m 27d
Posted
Hey guys,
I was looking at my standard sway bar (front) and noticed there is enough room to drill a second hole just behind the standard bolt holes. This would theoretically make the bolts closer the bushes, and inturn stiffen the sway bar setting. My question is, can anyone see an issue in doing so? The bolt holes on the "whiteline" adjustable bars are only mm's apart from each other yet supposedly make a noticable difference between each setting. I cant see why it cant be done to the standard one at a cost of zero dollars!
What's your thoughts.
  • Member For: 19y 5m 7d
Posted
No idea but it's worth looking in to, even if you stuff it up you can easily get another bar from the wreckers for stuff all.
  • Member For: 20y 1m 2d
Posted
I got whiteline ones, one of the best mods ever... If you can pull it off using the standard ones I say go for it..
  • Italian Stig!!
  • Member For: 15y 7m 27d
Posted
Man you notice difference driving since you put the whiteline swaybar ?? and how much they set you back? $$
  • ...JD TUNING ADELAIDE...
  • Member For: 18y 3m 23d
Posted
on a b series the whiteline bars are one of the best mods to date imho and at less than 330 for front and back do it, from memory front was like 170 plus 15 delivery(front), and just the front was amazing then the rear really does finish it off
Posted
Yeah what JETSNOT said, huge difference.. The car fells a lot sharper and less of a heavy boat.. I got mine off a forum member for $200 both front and rear..
  • Italian Stig!!
Posted
that's not to bad the price on them I might get set for mine :locomotive:
Posted
I think the size we use is 27mm for the front and 22mm for the rear, but make sure.. You can also get adjustable ones, but I've never used them so can't comment, bit more expensive I think too, but seriously how often are you gonna adjust them?
  • Italian Stig!!
Posted
ill do some home work man :) most likely not going adjust them I think.
  • Member For: 21y 2m 5d
Posted
If theres enough meat in the end of the bar to allow you to drill a second hole, without weakening the bar, then its worth a go. Cant hurt to try and the stiffness may actually be somewhere between that of a stock bar and an aftermarket bar. I found the 27mm bar really worked the front tyres hard, making it understeer more but certainly roll less.
