Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 3m 22d Gender: Male Location: Vic Posted 10/07/11 12:31 AM Share Posted 10/07/11 12:31 AM This is when dres thread would have been a good reference. I hope you read this dre! Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121647 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 15d Gender: Male Location: @ my laptop Posted 10/07/11 12:45 AM Share Posted 10/07/11 12:45 AM Something to consider re heat soak, when we talk back to back dyno runs, it pretty easy to understand, but that run through 1 gear only, on the road/track runs normally include rpm runs through several gears, the heat would have built after the run through first, would be increasing more so in 2nd and 3rd etc etc, so power will be falling due to hotter air not being as dense, the ecu pulling spark because of the temps etc etc. The retarded spark may result in hotter combustion temps which may cause slightly higher boost which will cause hotter intake temps etc, basically a circle affect Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121649 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 8m 20d Gender: Male Posted 10/07/11 12:45 AM Share Posted 10/07/11 12:45 AM there's a pwr bolt in on ebay for I think $800. Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121650 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 10m 23d Gender: Male Location: Zombie Birdhouse Posted 10/07/11 01:01 AM Share Posted 10/07/11 01:01 AM Well put Mick that's why heat soak is so noticable at the track or drags Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121652 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 6m 15d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 10/07/11 01:08 AM Share Posted 10/07/11 01:08 AM Or arthurs seat Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121654 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 10m 23d Gender: Male Location: Zombie Birdhouse Posted 10/07/11 01:10 AM Share Posted 10/07/11 01:10 AM Poor Arfur 1 Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121655 Share on other sites More sharing options...
f6mark Member 2,909 Member For: 14y 4m 28d Gender: Male Posted 10/07/11 01:11 AM Share Posted 10/07/11 01:11 AM Or arthurs seatLOL Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121656 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 11d Gender: Male Location: Adelaide Posted 10/07/11 01:18 AM Share Posted 10/07/11 01:18 AM Something to consider re heat soak, when we talk back to back dyno runs, it pretty easy to understand, but that run through 1 gear only, on the road/track runs normally include rpm runs through several gears, the heat would have built after the run through first, would be increasing more so in 2nd and 3rd etc etc, so power will be falling due to hotter air not being as dense, the ecu pulling spark because of the temps etc etc. The retarded spark may result in hotter combustion temps which may cause slightly higher boost which will cause hotter intake temps etc, basically a circle affecthow come its so easy for everyone to understand this now....... but when I was trying to explain how muy car made 400+ then got let down at the drags no one could comprehend this factor its not rocket surgery if anyones intrested I spent so close to bugger all to get my fg f6 into 11's and a one off 421rwkw dyno its all in the the injectors,actuator,e85 and the fattest tune it can handle but it WILL FALL OVER at half track but still do an 11 second pass get a bloke that can actually tune it hard and use 85 and your power will be there this isnt a dig at u ratter btw Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121657 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 11d Gender: Male Location: Adelaide Posted 10/07/11 01:36 AM Share Posted 10/07/11 01:36 AM heres a hot tip ladies 60lb dekas -$3952nd hand flash 3-$495/$595actuator 12psi $100hi flow the cat=freepipe kit so it holds together $380surge tank $1000tune cost ...............depends where u go???fit it all your self easy as sh*t this forum has all the info u need then get the tuner to tune it on e85 and u get a win situation or either 11's time slipnow how much did that all come to? Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121661 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 1m 16d Gender: Male Location: Melbourne Posted 10/07/11 02:10 AM Share Posted 10/07/11 02:10 AM But you bought a $40,000+ car isn't it mandatory to blow a heap of cash on it? Even if you don't need to to get results.. Link to comment https://www.fordxr6turbo.com/forum/topic/75755-f6-upgrade-confusion/page/3/#findComment-1121669 Share on other sites More sharing options...
