10/07/09 06:02 AM10/07/09 06:02 AM #1 Hey all...When I got my beloved beast I put a pod filter on her and well she made some very nice Woooooosh sounds haha... but I dont like running pod filters on these bad boys as I believe there better off in Jap built cars...So what do I use and how do I make that lovely induction like sucking in noise come about again? Atm I just have the stock airbox in her but will a K&N Filter do the trick? or do I have to like get another set up running?Any info will be great, cheers all.
10/07/09 06:20 AM10/07/09 06:20 AM #2 A K&N Panel filter will provide a bit more noise and adding the typhoon CAI or equivalent to your airbox will provide a second intake into the airbox and provides more induction sound for sure.Unfortunately with the stock airbox you will only ever get so much induction sound out of it. The best way is to run a pod filter off the turbo somehow (either in an airbox or under the battery setup). there is less pipework to quiet down the sound and better throttle response and the pod obviously gives you louder induction sound.
10/07/09 06:21 AM10/07/09 06:21 AM #3 wind up the boost whats wrong with the pod? I have the 4inch intake with the rapid airbox kit and its pretty much all u can hear. apart from the tyres screeching
10/07/09 06:23 AM10/07/09 06:23 AM #4 I have a pod setup in place of the stock airbox and it's loud enough.
10/07/09 06:46 AM10/07/09 06:46 AM #5 An under battery intake and more boost should do the trick. Can not wait to get mine done
10/07/09 08:46 AM10/07/09 08:46 AM #6 If you're still useing te stock pipework maybe try a Bluepower cold air box? they use a pod but look neater than factory and have a great induction noise
10/07/09 08:57 AM10/07/09 08:57 AM #7 However, if you want 350+ you're better off going for a CAI that goes straight to the turbo.
11/07/09 11:01 PM11/07/09 11:01 PM #9 Will an FG XR8 CAI bottom half and XR8 air snorkel increase induction noise?PAH
