April 13, 200818 yr #1 hi all. my ba is failing to lock the front passenger door im not sure how to test the mechanism. s there anything else I could check
April 13, 200818 yr #2 Sounds like a broken actualator (Spelling?)You can pick one up for about 100 bux on Ebay I think.
April 13, 200818 yr #4 Had the same problem a few weeks ago... Door actuator gone.. A guy sells them on ebay $65 changeover... or like $100 to buy
April 25, 200818 yr #5 Yep as above it is most likely your door actuator. If it makes a weird noise when you lock then that's pretty much it.I bought one from a wrecker for I think $70 and fitted it myself. Just make sure the little rod that you get is the same as the original one. I just had to swap them around after putting it in and realizing it was wrong! very easy to do.
November 14, 200817 yr #7 Easy enough job to do for the back door too? mine's left's not unlocking, and sounds like the actuator/arm's come loose.CheersDanSame Same, but Different?? Edited November 14, 200817 yr by Superdan
November 16, 200817 yr #8 back on topic chaps, keep it clean. There are some protagonists who cannot afford any more warnings.Nuff said
