  • WOT?
  • Moderating Team
  • Member For: 12y 4m 23d
Make sure you measure the temp of the outflow - will answer the question that started the topic in the first place :P
  • Bronze Donating Members
  • Member For: 14y 2m 23d
Do you think if you ate some of that ghost chilli hot sauce in a capsule it would destroy your guts? Or is just your tastebuds, nasal cavity, etc that can't handle the heat?
  • WOT?
  • Moderating Team
The capsaisin sp?? triggers pain receptors in the mouth etc. I don't think we have any on the inside, but may be some action in the form of reflux/burping that could be a bit of fun?
Depending on how it got digested it could be fun on the way out too.
edit: or.... it could kill you :S
Edited by raband
  • Member For: 15y 8m 23d
My rule of thumb is to hold it pointing directly down beside me and aim it at the surface.. I generally take about 10 readings anyway.. But yeah I was aware of the reflective surfaces.. just checking there wasn't some other numpty thing I could of been doing to skew the readings..
We were trying to use them to get a spray temp for bitumen (ie: temperature of the liquid leaving the spray truck before contacting the ground).. I was having no luck with that so I just went back to filling a tin with spray and then dropping a pencil thermometer in..
I only use it for:
Asphalt
BTB
Bitumen Sealing
various objects in or near the car when I'm bored..
Clicky this and tell the boss to need the 640 (great for doing the last thing you listed at night) was the best toy I had in the old job
