Chief_XR6T Member 425 Member For: 19y 5m 27d Gender: Female Location: Adelaide Posted 30/12/07 07:44 AM Posted 30/12/07 07:44 AM (edited) those are the pipes only one is pictured in the pic but ya theres anther one a bit behindwas wondering how do I unclamp them I tried with everything assembled and couldn't Edited 30/12/07 07:56 AM by Chief_XR6T
Chief_XR6T Member 425 Member For: 19y 5m 27d Gender: Female Location: Adelaide Posted 30/12/07 01:14 PM Posted 30/12/07 01:14 PM Also was wondering is there anything I need to know about cam phasers ?Are there any spacers under the garnish I should know about ?Appreciate the help everyone
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 5m 5d Gender: Male Location: Victoria Posted 30/12/07 01:16 PM Posted 30/12/07 01:16 PM You don't need to take that hose off.Nothing on the phasers, just don't touch them.
Chief_XR6T Member 425 Member For: 19y 5m 27d Gender: Female Location: Adelaide Posted 30/12/07 11:55 PM Posted 30/12/07 11:55 PM im going to the shops to buy some plugs rite now not sure on part number and gap but il read thru posts
Johnny G Team Grandpa Qualified Legacy Donating Member 809 Member For: 21y 7m 18d Gender: Male Location: Brisbane North. Posted 31/12/07 12:49 AM Posted 31/12/07 12:49 AM Make sure you re-install the coil packs all the way home onto the plug, and that the black cover (which holds the coil packs firmly in place on the plug wells - note the reliefs in the underside of it's moulding) is bolted down as per how it came off, being careful to re-run the wires clear of any pinch points. Don't miss any of those bolts, as it may cause movement in the packs and poor connection with the head of the plug unit. The one at the back is a pr!k to get too - but it's a good insurance policy.
Chief_XR6T Member 425 Member For: 19y 5m 27d Gender: Female Location: Adelaide Posted 31/12/07 01:09 AM Posted 31/12/07 01:09 AM im doing the plugs rite nowI started to do plug #2, my socket is not long enough so ya need a extension barso I tought ya il do 1 plug to see how cooked they are with the el cheapo $8 T bar toolgues what farken happens the tool stripped as int he plug was to tight so do I WD40 them or what im so angry and its 41C out here
tab Sucker Moderating Team 32,303 Member For: 22y 5m 6d Gender: Male Location: Brisbane Posted 31/12/07 01:28 AM Posted 31/12/07 01:28 AM
ms700 Moderating Team 10,170 Member For: 23y 8m Gender: Male Location: Sydney Posted 31/12/07 01:31 AM Posted 31/12/07 01:31 AM Umm, by the sounds of things, you might be best to do a dummy run of the car idling, to make sure you re-connected all of the coil packs correctly, before you go re-installing all of the black crossover pieces.......
Johnny G Team Grandpa Qualified Legacy Donating Member 809 Member For: 21y 7m 18d Gender: Male Location: Brisbane North. Posted 31/12/07 03:12 AM Posted 31/12/07 03:12 AM Geez Chief! Find a cool spot and wait til the sun is o'er the yard arm, and pour yourself a shandy!If you've stripped the socket, it was eiether a/ a dodgy one or b/ wrong size. The plugs are well recessed in the head and yes - you will need an extension. Shout yourself a long length plug socket with gripper, as well as a flexi joint - you'll never regret it.
Maximus Member 1,627 Member For: 19y 6m 20d Gender: Male Location: Slip Sliding Away Posted 31/12/07 03:22 AM Posted 31/12/07 03:22 AM WHolly Sh1t Chief. You are doing the Plugs in this heat.You must be crazy.I know this is going to sound stupid, but are you sure you were turning it the right way???They shouldn't be that tight that you damaged the socket.Anyhow make sure you have heaps of sunscreen on as it is says its 38 outside but that sun makes it feel like 50.
