TIMXR6T Member 116 Member For: 21y 1m 3d Location: Shire Posted 25/03/07 12:55 AM Posted 25/03/07 12:55 AM Hi guys Just checking to make sure. Are the spark plugs located under the heat shield.
Ninka Legacy Donating Member 1,850 Member For: 23y 9m 11d Gender: Male Location: Perth, WA Posted 25/03/07 12:58 AM Posted 25/03/07 12:58 AM Hmm, no they are under the plastic cover on top of the engine
TIMXR6T Member 116 Member For: 21y 1m 3d Location: Shire Posted 25/03/07 01:03 AM Author Posted 25/03/07 01:03 AM Under the cross over pipe.
Ninka Legacy Donating Member 1,850 Member For: 23y 9m 11d Gender: Male Location: Perth, WA Posted 25/03/07 01:09 AM Posted 25/03/07 01:09 AM Yes, there is a black cover which runs the length of the engine, and is held with about 8 socket head screws, they are under there.If you remove the cover, you will see the ignition coils and the wiring, which has to be disconnected and the coils pulled up to get to the plugs.Be aware that they are deep in the head, and no 6 cylinder is a bastard to get to.Oh, also they are the small size hex, so you need a socket for that.
TIMXR6T Member 116 Member For: 21y 1m 3d Location: Shire Posted 25/03/07 02:41 AM Author Posted 25/03/07 02:41 AM Thanks for your help. You right about the No 6. That was a hard one to do.
Max Power Member 381 Member For: 22y 5m 2d Location: MENAI, NSW Posted 25/03/07 12:27 PM Posted 25/03/07 12:27 PM Had a little chuckle when I saw the title. Have to admit, the same happened to me a couple of years ago. I had the new plugs ready to go and was stumped when I removed the heat shield and couldnt find the old plugs. Got under the car and couldnt find them under the inlet manifold either. Its funny now looking back but unless youre told its not that obvious. Im expecting someone to come on now (probably envy-t) and say something like...if the cyls are vertical and if theres 4 valves per cyl then the plug will be mounted in a vertical and central position to the cyl. (ha! - got in 1st)
Chief_XR6T Member 425 Member For: 19y 6m Gender: Female Location: Adelaide Posted 04/08/07 11:52 AM Posted 04/08/07 11:52 AM Yes, there is a black cover which runs the length of the engine, and is held with about 8 socket head screws, they are under there.Be aware that they are deep in the head, and no 6 cylinder is a bastard to get to.Oh, also they are the small size hex, so you need a socket for that.So if there a bastard to get to how would you messure the gap with the feeler guage ?
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 5m 9d Gender: Male Location: Victoria Posted 04/08/07 12:31 PM Posted 04/08/07 12:31 PM The plug has to come out if you're going to measure the gap.With the right tools they all come out easily.
ENVY-T CNUTOX Legacy Donating Member 3,098 Member For: 23y 8m 29d Gender: Male Location: Not sure? Posted 04/08/07 10:56 PM Posted 04/08/07 10:56 PM Had a little chuckle when I saw the title. Have to admit, the same happened to me a couple of years ago. I had the new plugs ready to go and was stumped when I removed the heat shield and couldnt find the old plugs. Got under the car and couldnt find them under the inlet manifold either. Its funny now looking back but unless youre told its not that obvious. Im expecting someone to come on now (probably envy-t) and say something like...if the cyls are vertical and if theres 4 valves per cyl then the plug will be mounted in a vertical and central position to the cyl. (ha! - got in 1st)Arthur, your too nice to make fun off, ya friggin chopstick! lolThey're in the exhaust!Oh and you outdid me on the plugs, I woulda just said your a dickhead and moved on!
Chief_XR6T Member 425 Member For: 19y 6m Gender: Female Location: Adelaide Posted 19/10/07 10:45 AM Posted 19/10/07 10:45 AM so am any tips on a noob changing the spark plugs I just need a bit of help on geting to emso remove the 8 bolts on the black piece of plastic and with that plastic is there a gasket to stop oil leaking?cause I was thinking the whole rocker cover had to come ofand any prices on spark plugs?
