masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 27d Gender: Male Location: WA, Perth Posted 20/04/14 10:59 AM Share Posted 20/04/14 10:59 AM How do you clean the filter? Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1466622 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m Gender: Male Location: Perth Posted 20/04/14 11:04 AM Share Posted 20/04/14 11:04 AM Throw it in the bin.But seriously, its 70 microns ( I have measured). If its contaminated solvent and air pressure wont clean it. And you can only tell under the microscope if its clean.If you feel you MUST have one , just install a new one every time you think you need to CLEAN it. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1466626 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 4d Gender: Male Location: Perth Posted 20/04/14 11:05 AM Author Share Posted 20/04/14 11:05 AM its 70 microns ( i have measured). With what?? Your Wang? (boom tish) 1 Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1466627 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m Gender: Male Location: Perth Posted 20/04/14 11:09 AM Share Posted 20/04/14 11:09 AM Yep--- that's me in the painting. (before I got a GUT). 1 Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1466628 Share on other sites More sharing options...
ljf12 Donating Members 20 Member For: 14y 5m 30d Posted 26/05/14 03:40 PM Share Posted 26/05/14 03:40 PM According to Garrett maximum oil pressure to the turbocharger is 40 to 45 PSI, the built in restrictor is not there to achieve this. So if you go by what they recommend you would have to put a restrictor in the line because your oil pressure is going to be way more than 45 PSI.Has anyone ever measured the oil supply pressure with the factory screen in place? Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1474129 Share on other sites More sharing options...
pac23 Member 103 Member For: 13y 2m 1d Gender: Male Location: Sydney Posted 28/05/14 02:35 AM Share Posted 28/05/14 02:35 AM Correct me if I am wrong but wouldn't the oil supply fitting on the turbo have the restriction I only allow 40-45 psi???These turbos are not made specific for xr6 so considering that every engine and filtration system is different I would assume that Garrett would just restrict their turbo to suit their own specifications.. If this the case measuring line pressure will really tell you nothing.. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1474499 Share on other sites More sharing options...
ljf12 Donating Members 20 Member For: 14y 5m 30d Posted 28/05/14 03:10 AM Share Posted 28/05/14 03:10 AM How can it restrict to a known pressure if it doesn't know what the supply pressure is ? According to Garrett you need 40-45 before the turbocharger, clearly people are running much higher pressure with no obvious issues. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1474520 Share on other sites More sharing options...
Blue Oval Silver Donating Members 245 Member For: 12y 1m 7d Gender: Male Location: Gold Coast Posted 28/05/14 08:03 AM Share Posted 28/05/14 08:03 AM Just do oil change every 5000 and clean earls filter on every third change or around 15000km mark and no problems Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1474589 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 1m 23d Gender: Male Location: Central Coast Posted 28/05/14 09:18 AM Share Posted 28/05/14 09:18 AM Anyone know the fittings on the earls filter I'm just going to run my one without it Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1474611 Share on other sites More sharing options...
ljf12 Donating Members 20 Member For: 14y 5m 30d Posted 28/05/14 10:02 AM Share Posted 28/05/14 10:02 AM 4AN Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/38/#findComment-1474619 Share on other sites More sharing options...
