Romulus Legacy Donating Member 1,279 Member For: 21y 8m 19d Location: Perth Posted 20/11/06 11:43 PM Posted 20/11/06 11:43 PM Steve, I had a Pedders Camber/Caster kit fitted. The kit cost about $175 plus fitting. I also had Nolathane bushes fitted to the top arm to eliminate wheel deflection during hard braking and cornering.The car runs 2.5 deg negative camber, and 7.5 degrees positive caster. Drives and steers heaps better
Paradoxx Colossal Member Member 5,049 Member For: 22y 30d Gender: Male Location: Perth, WA Posted 21/11/06 02:32 AM Author Posted 21/11/06 02:32 AM Thanks for the info guys... interesting to see such a range of prices for the same item! And I wasnt going to get it lowered for a while yet...
XR06T Legacy Donating Member 4,146 Member For: 21y 3m Gender: Male Posted 21/11/06 03:16 AM Posted 21/11/06 03:16 AM Thanks for the info guys... interesting to see such a range of prices for the same item! And I wasnt going to get it lowered for a while yet...←DEFN shop around..
seventytwo Still have a turbo, it's just on a diesel. Legacy Donating Member 5,368 Member For: 21y 2m 16d Gender: Male Location: The 8th Dimension Posted 21/11/06 10:10 AM Posted 21/11/06 10:10 AM (edited) Any one want an top notch alignment in Nowra, try Selby's Suspensions ( between Super Crap Auto and Auto Bodgy) Edited 21/11/06 10:11 AM by seventytwo
HI PSI Member 1,589 Member For: 20y 3m 29d Gender: Male Location: Central Queensland Posted 23/11/06 10:00 AM Posted 23/11/06 10:00 AM I have also had big issues with tyres scrubbing in the inside of the tyre. I have king Ssl springs that were fitted to the car when I bought it. It runs a set of 19in 245 tyres. I bought it with 8500 Km on the clock and tyres were severely worn by 15 000 Km. Took it to my mate at pedders and found that it didn't have a camber kit in it. he fitted them evry cheap (Cashie). We rotated the tyres and gave it a wheel alignment. 500k's lates they were down to the canvas. Were fine when we rotated them. NOT IMPRESSED.... So got new tyres and straight back on the same machine for alignment check. All looked goo very minor toe adjoustment needed. not enoght tostuff the tyres like they did. So I got another alignment from another tyre dealer with brand new machine. His aligner did not have corect settings for my ride height.. 10mm too low.. ARGHHH!!!! So we looked at the figures anyway.... even with camber kit- not enough camber on L/H side Noithing drastic or tyre shredding there. We changed our total toe to 2.0. He said "If this doesn't work - raise your car... "Fat chance. Mat from pedder showed me the distance the wheel goes backward under heavy braking (It does move a LOT) by a quick 30 km - 0 braking display in the Pedders car park. he suggests nolothane buses in front of the wishbone. haven't done that yet but tyers have about 600 km on them and appear to be fine (So far). I know that this is a long post, but I thought that big wheels are to expensive to screw up. I hope that this helps. I will keep you posted......
Ford_Power Member 798 Member For: 23y 5m 22d Posted 28/11/06 02:51 AM Posted 28/11/06 02:51 AM Hey Steve,I have used WA Suspensions since 1998 on my cars as they always do a good job, and they take care with my cars.I go there every 15000kms to get a wheel alignment just as a precaution, and if no adjustment is required, they never charge me.
Paradoxx Colossal Member Member 5,049 Member For: 22y 30d Gender: Male Location: Perth, WA Posted 28/11/06 12:23 PM Author Posted 28/11/06 12:23 PM Well I shopped around and took it to pedders in Joondalup. They were very helpful and for $110 I now have perfectly aligned wheels and suspension. They had to align the rears aswell because the main control arms on BOTH sides weren't secured by the dealer last time the diff was out. The guy under the car unscrewed both of the bolts with his hands... NOT GOOD But now I have new tyres on the front (Maxxis 235/40 R18 for $199) and the car drives straight as it should!! They did a good job Ford... watch out
IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 15d Gender: Male Location: OZ Posted 28/11/06 12:36 PM Posted 28/11/06 12:36 PM Yeah tell me about it Steve.... damn ford $hit me some times. Though Pedders in Osbourne Park were useless.
mickey_gee Member 593 Member For: 21y 11m 8d Gender: Male Location: Newcastle NSW Posted 28/11/06 04:37 PM Posted 28/11/06 04:37 PM Steve, I had a Pedders Camber/Caster kit fitted. The kit cost about $175 plus fitting. I also had Nolathane bushes fitted to the top arm to eliminate wheel deflection during hard braking and cornering.The car runs 2.5 deg negative camber, and 7.5 degrees positive caster. Drives and steers heaps better ←How much were the bushes? Did you get the hydarulic rubber dampers replaced? it looks like that is the only place anything in the sterring system can flex and I want to know if they can be upgraded?MG
XR06T Legacy Donating Member 4,146 Member For: 21y 3m Gender: Male Posted 29/11/06 12:44 AM Posted 29/11/06 12:44 AM did you get maxxis ma-v1 tyres??I am gonna get these too.. whaddya rekon so far??comparo to dunlops?
