Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 4m 27d Gender: Male Location: Victoria Posted 30/03/06 07:32 AM Posted 30/03/06 07:32 AM Actually most of the kits for the XR6T advertise power output in flywheel kilowatt terms.
Paradoxx Colossal Member Member 5,049 Member For: 22y 29d Gender: Male Location: Perth, WA Posted 30/03/06 08:34 AM Posted 30/03/06 08:34 AM
OzWest Member 9 Member For: 20y 5m 25d Location: Katanning Posted 30/03/06 09:57 AM Author Posted 30/03/06 09:57 AM Thanks for advice to date. XXXR6T, I do infact live in the West but not Perth. I live in Katanning is about 2.5Hrs South East so I don't think I will be making it up this weekend. Will definately keep my eyes open for future evens though.As for local guys in this town I don't believe any of them would even have a clue where to begin with these cars. Heck, I won't even let the Local Ford dealership where I brought it from touch it! Katanning has from it know, one of the oldest "Ford" dealerships in the state and I think their service long since retired with the inital founders. Nice people, just know nothing about the product.Anyway, thanks for the responses will do a bit of digging around this site.Cheers and Beers!
G6ET8U Playing with Sports Bikes... Legacy Donating Member 1,927 Member For: 20y 10m 24d Gender: Male Location: Whistling, GTX. Posted 30/03/06 10:59 AM Posted 30/03/06 10:59 AM Nice one mate!!I have just come out of my warranty (March 06) and I am, as of tommorow(8am to be exact... not that I am counting...), getting my car edited 'only' by Nizpro here in Melbourne, I already have a cold air intake and K&N filter, I will report back tommorow afternoon as to my results...Jack
C.S.I Member 651 Member For: 21y 9m 6d Gender: Male Location: Gold Coast Posted 30/03/06 11:28 AM Posted 30/03/06 11:28 AM I was talking fwkw for the poor bloke. And it would be good if he could make the Journey to Perth, just so then he would be hooked, and another Edit $old :-)Alan
Mildman Member 149 Member For: 20y 10m 11d Posted 31/03/06 12:29 AM Posted 31/03/06 12:29 AM I've been studying up on some of the most effective and reliable mods out there for the T, the conclusion I keep coming to is.APS Phase 2 Hardware (by APS)Custom EDIT (by HPF or Nizpro)an easy $10K I'd say but done once, done right.If only APS were as skilled at Edit as HPF or Nizpro - they could then be a one stop shop.Disclaimer: As I haven't got the mods it's all just fancy book learning here...
Paradoxx Colossal Member Member 5,049 Member For: 22y 29d Gender: Male Location: Perth, WA Posted 31/03/06 12:45 AM Posted 31/03/06 12:45 AM They all sound nice, but make sure you do all your research first! You might find you can retain the stock look of the engine bay and have just as much power as someone with a cobra stage 2 kit... but that's why you are here I guess Happy learning
Mildman Member 149 Member For: 20y 10m 11d Posted 31/03/06 02:03 AM Posted 31/03/06 02:03 AM Hmm...had a look at the Nizpro hardware (apologies for any thread highjacking)from Nizpro site http://www.nizpro.com.au/cobra_kits_main.htmlNizEdit and custom tune• 6 x high performance fuel injectors• Custom cast alloy rocker cover garnish• Custom cast alloy intake plenum• Custom intercooler hoses• Cast alloy throttle body adaptor• Cast alloy thermostat housing• K&N air filter• Fibreglass aid box • Injectors (XRT 350 and Stage 3)• Inlet Manifold Studs• Heat shrink• Oil breather hose• PCV hose• Hose clamps• Numerous cable ties• Odyssey battery• Battery box• Battery cable• Battery cable clips• Large intercooler• Inlet Manifold, Intercooler, Intake Manifold and Battery tray nuts• Brass fittings for plenum intake pipe, breather return hose and thermostat housing• Several bolts, washers, T-pieces, loom extensions, and an earth clipThis from HP-F http://www.hp-f.com.au/product+details?pid...&keywords=&pg=11 x Capa Ford flash tuner with custom tune. 1 x K&N Flat panel air filter. 1 x 2nd cold air intake modification (XR8). 1 x Turbo back Diflippo exhaust system with high flow cat. 6 x 42Lb high flow injectors. 1 x Set of Perfomance valve springs and retainers. 1 x 180 deg Thermostat. All labour to fit above components including re-gapping spark plugsand this from APS - (paraphrased) http://www.airpowersystems.com.au/falcon/phase_ii.htmAPS PHASE II High Output System includes APS Cold Air Intake System Direct Plug In Unichip Programmable Engine Control Unit (which we don't want)APS DR Series High Output Exhaust System APS High Flow Stainless Steel Monolith Catalytic Convertor High Volume Fuel InjectorsTo summarise:Nizpro: Edit with bigger injectors, intercooler and CAI approx 395fwkw ??rwkwHP-F : Edit with bigger injectiors, exhaust, CAI, valve springs approx 294rwkw (400fwkw)APS : Unichip with bigger injectors, exhaust, CAI. 290rwkw (330fwkw)Interesting the difference between APS and HP-F with the same rwkw and vastly different fwkw....Lunch time - will edit with some conclusions later
Paradoxx Colossal Member Member 5,049 Member For: 22y 29d Gender: Male Location: Perth, WA Posted 31/03/06 02:13 AM Posted 31/03/06 02:13 AM That doesnt make any sense, unless HP-F or APS modify the gearbox
Mildman Member 149 Member For: 20y 10m 11d Posted 31/03/06 03:17 AM Posted 31/03/06 03:17 AM (edited) I agree, someone has made some generous estimates of drive train losses I would imagine....I'd doubt the gearbox and diff oil would be able to dissapate 100+kW of heat.As to some conclusions:I'm still a little confused why Nizpro go for a bigger intercooler but no upgrade to the exhaust. - unless the factory exhaust does indeed flow that well.They all upgrade injectors and add the XR8 CAI under the headlight.Nizpro seem to advertise the most holistic approach, but the intercooler/no exhaust decision doesn't seem right.The impression I had with exhausts was that APS make the highest quality XR6T exhaust, the CAI is the same all-round, the injectors probably don't vary much between kits.(Although I haven't heard much about the quality of the Turbo back Diflippo exhaust system with high flow cat.)Posted Today, 11:45 AM They all sound nice, but make sure you do all your research first! You might find you can retain the stock look of the engine bay and have just as much power as someone with a cobra stage 2 kit... but that's why you are here I guess Happy learningI think I understand your point to, which is with just an CAPA custom tune you can make some serious power with having to do the hardware upgrades. - My main goal would be to have a car that will travel in the high 12's, without being a pig to drive -Best way to continue with researching potential mod strategies will have to be chatting to guys on the XR6T cruises! Edited 31/03/06 03:19 AM by Mildman
