senna_T Forged Member Lifetime Members 15,818 Member For: 17y 2m 20d Gender: Male Location: SW Sydney Posted 02/07/08 03:47 AM Share Posted 02/07/08 03:47 AM If you had a hollow cat it most probably would be overboosting. However if the cat has collapsedit could be the reason your car doesn't want to rev.Either way it will need replacing unless you want to get the car custom tuned. Link to comment Share on other sites More sharing options...
antigravity Member 332 Member For: 17y 7m 10d Gender: Male Location: Sunshine Coast!!!! QLD Posted 02/07/08 04:30 AM Share Posted 02/07/08 04:30 AM But if the cat was stuffed, it would have been stuffed before I removed the central muffler, and it used to rev fine then.I will be replacing the exhaust shortly anyway, but in the meantime, I want to still enjoy driving the T!Will reset the ECU by disconnecting the battery and let it learn again. See what happens. Link to comment Share on other sites More sharing options...
antigravity Member 332 Member For: 17y 7m 10d Gender: Male Location: Sunshine Coast!!!! QLD Posted 03/07/08 10:39 AM Share Posted 03/07/08 10:39 AM (edited) Here's what my car sounds like at the moment:JqKN02in_8c Edited 03/07/08 10:40 AM by antigravity Link to comment Share on other sites More sharing options...
nathen ride the lightning Donating Members 338 Member For: 17y 6m 17d Gender: Male Location: sydney Posted 16/07/08 02:18 PM Share Posted 16/07/08 02:18 PM if you remove the centre muffler do you have to flash tune the car?my car has standard tune aftermarket cooler Link to comment Share on other sites More sharing options...
sensoryamusia Member 398 Member For: 16y 1m 18d Gender: Male Location: leeming, PERTH Posted 16/07/08 10:19 PM Share Posted 16/07/08 10:19 PM if you remove the centre muffler do you have to flash tune the car?my car has standard tune aftermarket coolernopeI have the muffler removed, stock tune and aftermarket cooler and no probs here Link to comment Share on other sites More sharing options...
vetha Member 61 Member For: 16y 2m 22d Gender: Male Location: Melb, VIC Posted 02/08/08 08:45 AM Share Posted 02/08/08 08:45 AM howd u get it done mannn every place ive been they like can't remove centre muffler itll be too loud blah blah Link to comment Share on other sites More sharing options...
Maximus Member 1,627 Member For: 17y 1m 17d Gender: Male Location: Slip Sliding Away Posted 02/08/08 08:47 AM Share Posted 02/08/08 08:47 AM howd u get it done mannn every place ive been they like can't remove centre muffler itll be too loud blah blahSomeone will do it.What loaction you in. Someone here will be in the same area and tell you where they got theirs done.CheersJR Link to comment Share on other sites More sharing options...
Nashy Member 96 Member For: 15y 11m Location: Tully, QLD Posted 25/08/08 01:42 AM Share Posted 25/08/08 01:42 AM got quoted $187 to do this to my FG..Said sounded bit more exspensive that what other have paid to get this done and guy reckoned it was that because they use stainless to do it. Link to comment Share on other sites More sharing options...
tollz Member 9 Member For: 15y 7m 13d Gender: Male Location: Perth Posted 14/09/08 01:16 PM Share Posted 14/09/08 01:16 PM Twin 3' stainless steel cat back exhaust, thoughts? Im not looking to go mega with the exhaust but I know someone in the industry n I can get that done for $1100 fitted..Good choice? Link to comment Share on other sites More sharing options...
grugman Member 3 Member For: 15y 9m 18d Gender: Male Location: Adelaide Posted 19/09/08 03:18 PM Share Posted 19/09/08 03:18 PM I replaced everything from the cat back with single 3 inch stainless, resonator and junbl muffler and the difference is awesome gone from a big vacuum cleaner to a tough sounding car. there is a little drone but was told this would settle as the carbon builds up. wasn't chasing performance just a reasonable note but managed to grabb a few kw's but did managed to grabb a noticeable gain in the middle and response very slightly improved Link to comment Share on other sites More sharing options...
