Search the Community
Showing results for tags 'ford ecu'.
  • Search By Tags
  • Search By Author
  • Vehicle Discussions
    • XR6 Turbo
    • FPV & Tickford
    • XR8 & GT
    • G6E Turbo
    • Falcon Utes (UTEopia)
    • Territory Turbo
    • Euro Turbo Fords (Focus & Mondeo XR5)
    • Ford Discussion
    • Ford 4.0L N/A
    • Engine Conversions & Swaps
  • Community Zone
    • General Automotive Talk
    • Off-Topic
    • Media & Projects
    • Track & Strip Racing
    • Photo Gallery
  • Tech Workshops
    • General Tech
    • Audio & Visual
    • Interior & Exterior Workshop
    • Exhaust Workshop
    • Electrics Workshop
    • Wheels and Tyres
    • Suspension and Handling
    • Brakes
    • Driveline Workshop
    • Forced Induction Workshop
    • Engine Management & Fuel Systems
    • Engine Workshop
    • High Power Builds (300+ Club)
  • Regional Events
    • General Discussion
    • East Coast (NSW, ACT, QLD)
    • Southern States (VIC, SA, TAS)
    • Western & Northern Australia (WA, NT)
    • New Zealand
  • Buy & Sell
    • Classifieds & Group Buys
  • The Site
    • Site Announcements
    • Site Support & Feedback
Product Groups
  • Advertisements
  • DM Packages
  • Merchandise
    • Stickers
    • Key Rings
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Found 1 result
  1. THE UNFORTUNATE END TO ALL BA FORD FALCONS ARTICAL HERE! ALL BA PCM/ECU'S WILL ALWAYS FAIL THERES NO PERMANENT FIX ONLY TEMPORARY AT GREAT EXPENSE AS OF 2025 ITS 2K UPTO 3K FOR REPAIRS ITS NOT IF IT WILL FAIL ITS WHEN SADLY countless workshops have customers coming in for failed PCMs in the BA series Daily at one stage at its peak there had been 8340 people around Australia in 24 hours with BA PCM Failure Extensive Research and Automotive Experts have found the following. - so after doing tons of research again and speaking with Haltech, and Hootons harnesess which they done whats needed for the whole permanent fix on the Mighty Car Mods XR8 Series videos, so I found with the BA ECUs they actually used Lead Free solder, as to be more environmentally friendly which is why they ended up failing XR6T and XR8 Fail quicker because the engine bay temps are way higher but ALL BA PCM/ECU'S WILL ALWAYS FAIL ITS NOT IF ITS WHEN SADLY as it's 110% unavoidable but you can stretch the life of it for like 12 months by paying 2k to repair but even then it could break the next day because these BA ECUS are all bad and being 20 years old they are all moments away from failing the same way if you hit a pothole speed bump anything ready since all the BA ECUs are made the same way and there is no permanent fix its only all temporary only permanent solution is haltec which is all up 5 to 6 grand I was looking online just before to see if it was possible to reflow the joints with lead solder so that even the repaired ecus that you send to get repaired can be permanently fixed but it's basically impossible, so when you send you're pcm ecu to be repaired they have to use the lead free solder on the repaired ecu, which after asking a few people on the xr8 page and xr6T pages aswell they also confirmed they had to end up getting a whole stand alone haltech ecu setup which cost around 6k with all the adapter harneses and so on for the XR8 models and around 5 5500 for 6 cylinder models with the BTR 4 speed and manual versions which is a crazy price So when it went over that bump that would of caused that lead solder to end up cracking or snapping apart when was why when I poured boiling water over the ecu it was able to start up untill it cooled down and then wouldn't be connected to the solder and shut off So it would of happend any time any day anywhere and just driving to the shop then parking getting shopping you can come out goto start you're BA and it'll have cracked or snapped and won't work anymore if it does it'll have misfires or basically limp mode very sluggish and just absolutely terrible to drive which you can't avoid and eventually it'll snap or crack more and then it'll simply not start the car anymore and you're choice is either keep repairs them for 2-3k with prices rising weekly or go the haltech route 5-6k but beware if going haltech you're car is now illegal to be on the road and will be impounded instantly which is a real shame sadly but it's the same laws in all of Australia so basically the days of the BA FALCON are coming to a close and soon everyone will just have a garden ordiment to look at and remember all the memories it's sad but it's unfortunately how it is with the BA falcons, everything was fixed in the BF FG Models and this PCM issue is non exisistant in the BF FG Models but for BA sadly there time has come to a end. - Raining Pistons
