Everything posted by MYWPN
Justice System Is Fcuked
bit of favourtism towards the hot female I think, it is absolutely ridicolous that she got off, people wonder why others have anger towards police and justice
Croydon Racing Developments Any Good?
Ive dealt with him years ago when turboing my suzuki, very helpful guy, cant be too bad, they have a customer with his work ute BA XR6 with a tray running 540rwkw, drives it every day for work
- Fractured My Sachrum
Master G & Shahin Into The 10's
I agree that is a really good 60ft, I only wish I could get mine to hook up and anything near 3500rpm. well done
Clutch Problems
sorry fats but I think you ate your words sorry but that had to be said
Clutch Problems
having not so capable clutches are meant to be there to cushion the impact on the gearbox not totally destroy it , if ford had a half decent clutch assy for a starters that would not have happened
044 And Swirl Pot
sedans are different to utes, with the ute you can run alot lower fuel level. the higher the power with the sedans the worse they get. I remember craig had to run over 3 quarters of a tank to drag his when it was making 385ish rwkw
044 And Swirl Pot
I had fuel surge once down the strip and it had about 10-15litres in it, anything above that and it's fine though.
A Huge Thumbs Down For Nuford Wangara
That s correct they do give a quote, we always over quote. but with a job that big I wwill not start if they havent written a quote on the front, no qoute on the front of the repair order means that they havent told the customer how much. and at that stage we will ring the customer and verify the dollar figure
it does not matter whether he signed it, because it was not sighned with a quote beside it, trust me I deal with sort of thing everyday
tell me about it, it cost me between $20-$30 trade.( It was a while ago so I cant remember exactly, but it was not low $20's)
THEY SHOULD QUOTE BUT DONT ALWAYS, I WORK FOR A DEALER AND AS LONG AS YOU DIDNT AUTHORISE THERE WORK THEN YOU HAVE ALL THE RIGHT TO TELL THEM TO RETURN IT BACK, WORST CASE YOU PAY FOR OIL AND FILTER. IF YOU ARE THAT UPSET THEN DO IT. BUT ON ANOTHER NOTE YOU DID TAKE THE VEHICLE IN FOR 100,000 SERVICE AND IF YOU LOOKED IN THE BOOK FIRST IT TELLS YOU EVERYTHING THAT IS TO BE REPLACED OR IF YOU DONT HAVE A BOOK THEN ASK WHAT IS TO BE DONE!!!
15" wheels for xr6 turbo
15 inch steel rims wont fit without modifying the brakes but there are some aftermarket alloy wheels that do fit over the standard brakes. Hope that hepls
Tailgating
I must admit if someone is driving way too slow like 60km/h in an 80km'h zone I will tailgate them and if that doesnt work I will pass on double lines, only on one section of road on the way too my house , it gets a bit irritating when it happens ALL the time!
Best Times With A Stock Turbo.
Is it really, well there you go, I was told different. on another note you would be able to make higher than 400rwkw with race fuel, I was referring to a ball park figure of 400rwkw in an auto on pump fuel!
adams had high flow turbo. but they will handle a ten sec pass and up to 400rwkw
A 900hp+ Motor, What Do I Need?
with the 2jz you will not need to replace the bottom end for that power, those things are bullet proof that's assuming you have a supra
Hsv Gts-r 385kw On Sale October!
absolutely right about the corvette running mid 11's STOCK. . So I would say these things are going to be weapons. cant wait really, might have to trade up and twin turbo's
Has Anyone Seen This Anti speeding Add?
So your mate askes you to take him for a spin do you see how slow you can drive . Obviously people like going fast I must be hung like a cashew as well
T5 Still Alive!
I had a suzuki swift with 72 front wheel kw and broke 6 gearboxs in 12 months because it would axle tramp and thump into gears, I turbo'd it and running 182 front wheel kw and it would spin every gear except 4th and 5th and I had this setup for 2 years and only broke 1 box, the wheelspin was taking the pressure off the driveline but not the clutch (21 later)
- 0-100 Vid
T5 Still Alive!
Try some grippy tyres and see how long it holds
Supercharged E46 M3
Man that thing is a weapon, love it . He doesn't mind taking it easy
Et Streets
having big brakes you are limited to what you are able to use, with stock suspension and some et street radials, they should hook up fine. once you start running over 350rwkw I would look at replacing the rear brakes with stock ones and run a 15inch drag slick, you will need mags or you will have to modify the standard rear brakes to fit widened stockies, I found out the hard way.
Et Streets
The territory rims will take those tyres. Not sure on the 16 's, I know the premium brakes they will definetly fit over the brakes
