BAturb
Everything posted by BAturb
  1. good power in a work ute, you can never have enough for carting heavy loads, I also have a PWR cooler so there might be hope for me yet!!!!!
  2. definately need a re-tune, if its anything like when I fitted a larger IC you will have lean AFR's with the increased air flow
  3. hence the importance of a good relationship with your local tuner, not a traveling circus
  4. had the same prob not long ago, where the line joins under the windscreen on the passenger side, just pull them appart and clear the line to remove a possible air lock, worked a treat for me
  5. does the car still have stock injectors?
  6. DYNO FIGURES ARE JUST NUMBERS, do not be sucked into "the number is higher it must have more power" as you have found out the way it makes power, it is actually slower than what you had before, if you went to a tuner in your area you could go back and have the problem rectified there and then not having to wait for weeks with an "off tune", while it may seem good to have a rush of boost and have big wheel spin you will infact be going backwards
  7. I like it
  8. try a pwr cooler for around $170, I got mine from e-bay and fitted it behind the drivers fog light, kit came with everyting supplied
  9. if I had a car like that I wouldnt hesitate to show it off if someone wanted a look, seems suss
  10. always ready
  11. I couldnt recommend PWR coolers highly enough, the quality is fantastic and fittment was a breeze
  12. pic side by side with stock cooler (not my car)
  13. pic of the PWR installed
  14. late sat or sun for me, I work till 2.30pm on saturdays
  15. sounds good I might be in
  16. I had no trouble fitting my PWR cooler and I think its great, performs well and looks good too
  17. has anyone got any info on remote locking for the hard lids?
  18. under the new laws, it is not discrimination if the empoyer says theres not much work so either you go back to casual or there is no job
  19. under the new laws if an employer has less than 100 people then all they need to say is exactly what you have said, if she doesnt like it then what choice does she have, there is nothing much anyone can do
  20. BAturb
    Hi To All
    welcome, and shockwave would have to be the best colour, (but Im biased )
  21. that was told to me by a ford tech, most dealers dont know what it is or even to look for it, but if they find it and are a bit sus about things, all it takes is a call to Ford and they will find out
  22. the edit displays a certain code (not sure what it is) and if the dealer susspects anything and calls Ford they can then inform the dealer if it has been edited, BA or not
  23. personally I would not go for that its not enough and as for the overtime rates why not have time and half for 2 hours then double time after that and double time for as long as you are working
  24. judging by the only mods you have are the bigger cooler, you have overboost issues, if it didnt do it before with the stock cooler and it is doing it now with a bigger free flowing cooler, bing, there is your answer
