Everything posted by JGP
- Failure Of Inline Turbo Oil Filter (Earls)
F6 Secondary Intake And K&n
cheers rbjet, my main concern is its sucking hot air from the engine bay...will see about flexi hose
Whats Everyone Do For A Crust?
shouldn't get too many issues with the base software....I agree the IT guys must be flakes.... do you get contractors in for specific modules and customisations?
what would you use to close the stock airbox-left hand side hole?, where the standard under bonnet snorkel(not typhoon snorkel) used to go? When I upgraded the intercooler +cold side piping this had to go and now its open to the engine bay. I have a (dont laugh) plastic lid from a jar that fits perfectly but worried it might melt there....
Standard Diff Or 9"?
seems cheap to me... I remember waaaay back I had a 9" w/3.77 installed on my for about 2.5k, this is going back 13 or so yrs....goddam I had to work some extra shifts to get that thing ( I was student at the time)
big difference between SAP consultant and ERP systems, and computer technicians fixing desktop computers.
- Weight Training For Beginners
Brake Upgrades For A Ba
got quoted about 700 each for ap racing 4pot fronts http://www.compfriction.com.au/ Fraud quoted 700 each or so for the blue PBR 2pots....black were cheaper I think 500 or so...go figure
Zf Heat Exchange Replaced.
1600 dave ask mikesmodelcars(ebay coils) I got quoted $130
Is Ethanol Blended Fuel "evil"?
my car, BF2 has a tag on the fuel lid "E10 compliant" or something. I ran it a couple of times, pre-tuned and it seemed ok. I used to run my fairlane 5.0 NF on e10 95 for several years and didnt have issues. I mainly did that as the it would ping on 91. I think in the mid 90s standard unleaded was 95 octane.?
Im no deadlifting expert, but on the initial phase of the lift you might have rounding your shoulder and using your lower back to start the lift, which might have contributed. the only downside of this method is when you start hitting the heavier weights 160kg or so its easy to injure yourself.next time try push down with your heels on the initial part of the lift,keep you upper back straight. they are good, I had chronic back pain and started this lift 2 yrs ago, back is waay better now that I can even do bb bent over rows for the 1st time last week in about 8yrs.
not sure, the back extensions I used to do involved lying front facing with your stomach on a square large pad. your feet are hooked on some leg extension type roller pads. you would then do like a 'reverse situp' I.e. head towards the floor and back up, exercising your lower back. http://en.wikipedia.org/wiki/Back_extension
Coolant Flush W/o Radiator
do you have to remove the bottom air deflector? I was thinking the coolant might drip into it? also if you run the car for 3-5mins,switch off then drain and fill with cold hose water cant this cause issues?
Herrod Cai
- Herrod Cai
If OP is like me(not much of a mechanic), reversing a turbo side install is another trip to Pitlane- Herrod Cai
Yep, I put any pod filter is illegal with IC mods..my point being which one is easier to reverse in case you have to go through the pits? 'Turbo Intercooler' writing still is a stock item,maybe that's enough for no further checks? - Herrod Cai
