PSI40L
Everything posted by PSI40L
  1. PSI40L replied to a post in a topic in Ford Discussion
    I had mine up to 200kph on an up hill.sh*t I thought I was the only looney out there now I wanna see it go to 229 but not this weekend or maybe mmm lets see where I can go
  2. topic replied to PSI40L's CJF077 in Off-Topic
    Nice stroker crank ...mmm what rod ratio are we gonna run now...
  3. I did ...I did white xr6t with black tints and a radar unit on the centre console It was an under cover car it is roaming around broadway .... It pulled up next to me on the way home from work on parra rd it was sitting alot lower than mine in the rear aswell and sh*t it looked good
  4. topic replied to PSI40L's PSI40L in Off-Topic
    dont worry guys if u cant come I wont let u downill promise to put on a good show for all of us
  5. PSI40L replied to a post in a topic in General Tech
    Bigger radiator? the radiator its got on it is aluminium .that ll keep a race car cool for sure
  6. Gee I thought vct was controlled from ignition solenoids on camshaft is that how it works im gonna pull a rocker cover off r u serious??? Sticky solenoid I reckon it will drop a valve if the case????maybe it retard the timing before anything that's why it was shuddering... who knows???? maybe it something very simple where do we start .mr mods plz explain how it wrks do the camshaft solenoids actually advance cam duration or what...
  7. PSI40L replied to a post in a topic in Suspension and Handling
    look underneath boy s the barra has already shim style camber/castor kits get some shims dont waste the $300
  8. topic replied to PSI40L's Falchoon in XR6 Turbo
    Add the Koni adjustables like the man said. Interestingly enough I looked at the upper control arms the other day ford has already put the castor / camber kits in with 1 shim in the front there is enough room for usually6-7 shims in the front and 1 in the back this should give nearly -3 degree camber and +7 - 8 on the castor throw in a good front and rear sway bar .Get some progressive KING springs lowered and forget th wrxs,s3, and what ever else u want. Bathurst here we come.......
  9. picked the car last week from service they fixed the bonnet lever,engine light problem,crocky horns but went through the car and found a long scratch on the front bumper ran in side back to service showed the manenger in my utter frustration and he said "chris there is no problem we'll fix it ...anyway got home popped the bonnet to check all myfluid levels and to concern found some melted rubber on the tensioner pulley on the fan belt..What I notced it is been wearing the outside of the belt..the rubber is on top of the tensioner and a bit on the side of the motor so one of the other pulleys must be misaligned ...Here we go again...has anyone else noticed such a problem
  10. Dont think it was the heat mine happened on a cool night the whole motor was vibrating all in the cabin I thought it was fuel but what dirty filter pump and injectors everything is new it felt like it was pre - igniting switched it off restarted it and came good never had a problem since ford wont find a problem like that trust me unless it was dooing it consistantly
  11. topic replied to PSI40L's PSI40L in Off-Topic
    we are going to be cruzing guys not racing and there is no traffic on that day believe I go every year but any way you guys dont know what your missing out on ill be the first one there
  12. topic replied to PSI40L's CJF077 in Ford Discussion
    Let me just rephrase that hany F - first O - on R - Race D - Day
  13. PSI40L replied to a post in a topic in Ford Discussion
    ha go cj go
  14. topic replied to PSI40L's PSI40L in Off-Topic
    So xr8chic u coming ????
  15. a topic posted PSI40L in Off-Topic
    Every long weekend there is a major cruz ,that leaves from the shell Service Station on Kingsgrove rd near Homer st and cruzez down to Woolongong .they happen every long weekend ive honestly seen up to 1000 cars cruz down whether they are normal daily drivers, street machines, hotrods you name it they are there .Everyone meets at approximately 10.30 am and leaves the servo by about 11 -11.30 they cruz down to woolongong beach and go for lunch down there and spend the rest of the day...it is a good day out...so what do u reckon guys whos coming.....
  16. The difference between 95 and 98 RON is usually 2 or 3 cents. Not around sydney it isn't . Any way got a load of normal unleaded couple of weeks ago and didn't really see a difference makes me a bit sceptical sometimes of what I am really buying . I think the xr8 is 9.5: 1 comp u can easily run standard unleaded no problem. Fuel consumption who cares when u got V8 power...
  17. PSI40L replied to a post in a topic in Interior & Exterior Workshop
    thanx for that trevor I have to admit ive did go bit over board with the speed but I aint gonna mention any numbers ...but I wasn''t on it for that long and didnt feel that it had any noises or air leaks better get them to check it though
  18. Picked it up on the 6-12-02 and its got 4400kms I think im diving it too much nearly 1000 a week but guys "I just cant gt enough of this ".
  19. I would never buy a Expensive Daewoo mondie ive owned even the worst of fords series1 ea I have had xy replica gt ,xa, 3 xc , 1 xe , 1 xf, 2 ea ,2 eb, 1 el and now the ba now that's confidence and loyalty no holdens in this departmant I should be fords vip...
  20. PSI40L replied to a post in a topic in General Tech
    Dont like the thought of anyonyone else driving my baby what we do, we do together. has anyone ever heard of the statement . Never lend your car and your misses . Then theres rhetorical what if ? question u have to deal with.
  21. Loan car only for the weekend had to be back on monday 7am cause someone else had booked it and no more loan car available he reackons hows that for Ford Service
  22. went up to Nelson bay 2 wks ago and on the way back went to overtake someone floored the accelarator and went for it .notced on the dash , the engine light come on .Looked in the manual when I got home and read it is for the electonic throttle control .took it back to ford told me it will be ready at the end of the day. A week and a half later and still no car .they think it is the pedal itself that's the problem .The team manager said that the pedal has 3 sensors on it and the last 2 are causing an open circiut . funny I thought though the car was still drivable and the light was coming on only whilst accelarating . Didnt know if he was 100% in what he was saying .I then told him it is not good enough I need the problem rectified then he claimed that we havent had alot of training on these new models .(how positive doz that sound.) Anyway doz anyone have any idea on what could have caused the problem ... or what is causing it...I hope it isn't my heavy right foot...
  23. Why are we even talking & looking at holdens .we all know what they are we all know what they can do and how they go I think we should close the topic
  24. Popped the bonnet the other day and noticed the engine bay was very rough like it had been left with overspray and no paint pretty upsetting for 50k car .makes me wonder what else did they forget
  25. Dont forget guys evrything is still new. when it gets hot it will omit a smell for eg ever had a exhatst replacement for the first 100 kms even smoke comes off it from the protective coating they put on it. Give a bit of time and all will be well.
