Puffwagon Puff Gold Donating Members 15,135 Member For: 9y 2m 30d Gender: Male Location: South Australia Posted 26/10/22 02:50 AM Share Posted 26/10/22 02:50 AM 5 hours ago, k31th said: it's harder to tune as you need to adjust the manual controller and then separately adjust the tune It's easier to tune because you are just winding a screw rather than changing several tables and a half a dozen parameters. Using a boost tee means it will have a massive mid-range hump then fall over up top, so it's a bit sh*t in that regard and that's why you wouldn't do it that way. 1 Link to comment Share on other sites More sharing options...
Dat111 Member 30 Member For: 1y 11m 18d Posted 02/11/22 09:03 AM Author Share Posted 02/11/22 09:03 AM makes sence puff. thanks already got dropping off at 3800rpm (from 9psi to 6) Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,135 Member For: 9y 2m 30d Gender: Male Location: South Australia Posted 02/11/22 10:11 AM Share Posted 02/11/22 10:11 AM 1 hour ago, Dat111 said: already got dropping off at 3800rpm (from 9psi to 6) Yerp that's what you will see and it's the opposite of what you would want to see with a skinny rod motor. If you are using a NA pcm such as your case, you can just buy a cheapish electronic boost controller and you'll be sorted. It'll hold the boost flat until red line which will give you a lot more power, without putting too much boost into the mid range. Link to comment Share on other sites More sharing options...
Dat111 Member 30 Member For: 1y 11m 18d Posted 02/11/22 09:29 PM Author Share Posted 02/11/22 09:29 PM (edited) https://www.hybrid-power.com/product-page/new-hdi-super-electronic-boost-controller-se I seen this ages an ages ago. any thoughts on that? like to add to would it control boost eg not overshoot the boost like it is doing? hence using the garrett wastegate Edited 02/11/22 09:37 PM by Dat111 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 03/11/22 12:03 AM Share Posted 03/11/22 12:03 AM The problem is you then need a RPM generator device to work in with aftermarket EBC or they do exactly the same thing as a Boost T will…. MSD do a Tach driver device that you wire in, connect to the EBC then you’ll have controllable boost targets “IF” the wastegate/Port/Flap are set up correctly also ! 1 Link to comment Share on other sites More sharing options...
Dat111 Member 30 Member For: 1y 11m 18d Posted 03/11/22 01:01 AM Author Share Posted 03/11/22 01:01 AM hey @JETURBO thanks for the response man. basically, all I am wanting to do is flatten the boost curve. its a fully stock set up FG rear housing/B series Garrett actuator it wasn't ported. was told by a few people that it wouldnt need to be. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,135 Member For: 9y 2m 30d Gender: Male Location: South Australia Posted 03/11/22 01:51 AM Share Posted 03/11/22 01:51 AM You don't need an rpm input to run an ebc. Here's one example Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 03/11/22 02:20 AM Share Posted 03/11/22 02:20 AM (edited) It’s the same as every EBC these days… I’ve never used the GFB one but it suggests the same characteristics… That’s why the pinnacle of EBC’s ( Turbosmart EB2 ) offers RPM input fir this reason, if a vac line could do it all then they would Edited 03/11/22 02:23 AM by JETURBO Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,135 Member For: 9y 2m 30d Gender: Male Location: South Australia Posted 03/11/22 03:10 AM Share Posted 03/11/22 03:10 AM (edited) Yeah there are limitations for sure, when we're talking na conversations budget is usually the main deciding factor in parts choice. For all of that malarkey a turbo pcm is probably a better choice, I saw them available for $440 recently. Specific to the vehicle in question, we have no decent boost control now, maybe an actuator/spring change will do the job? It might need wg porting but it's a very cheap and easy to implement option. Edited 03/11/22 03:10 AM by Puffwagon Missed some punctuation Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 03/11/22 04:10 AM Share Posted 03/11/22 04:10 AM Agreed… cost being the factor definitely go factory or a flat out spring and or T for $90 Link to comment Share on other sites More sharing options...
