XR6T 520RWKW Member 40 Member For: 6y 3m 6d Posted 05/04/19 02:34 AM Share Posted 05/04/19 02:34 AM hi guys was tuning my FG the other day and notice it was breathing very heavily. the next day I brought the car home empty my catch can, replaced engine oil. still it is the breathing heavy specially after long drive when the car gets very hot but the temperature on dashboard never pass middle mark (I mean never over heat). anything wrong with engine can be serious issue. anyone having any idea what it could be? only thing is that it breath heavy. stem come out of catch can breather and engine oil in led. only having it for last 3 months, god knows wht previous owner did to the car. Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/ Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 3m 20d Gender: Male Location: SW Sydney Posted 05/04/19 03:29 AM Share Posted 05/04/19 03:29 AM Sounds like a possible heart condition to me, best get your vet to take a look. Of course it may just need a good rub down and fresh straw but good idea to check these things thoroughly. Another thing to consider is whether the clubsport mare next door is in heat Jokes aside, do you mean thermo fans are constantly coming on or what?? 11 hours ago, XR6T 520RWKW said: stem come out of catch can breather and engine oil in led. ^^ you'll have to break this bit down 11 hours ago, XR6T 520RWKW said: was tuning my FG the other day ^^^and this 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680792 Share on other sites More sharing options...
XR6T 520RWKW Member 40 Member For: 6y 3m 6d Posted 05/04/19 04:38 AM Author Share Posted 05/04/19 04:38 AM I mean steam come out of engine and catch can when pushing car hard. fan is ok,. I meant it never over heat or anything., Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680795 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 3m 20d Gender: Male Location: SW Sydney Posted 05/04/19 05:09 AM Share Posted 05/04/19 05:09 AM Ah, steam You've asked this question already, correct? As already said in one of the other threads, 'some' oil vapour from a vented catch can will be normal, IIRC your motor is built so there will be more blowby than a stock motor. However; 'a lot' of oil vapour means a lot of oil coming from somewhere, either a) your catch can is sh*t and isn't separating the oil/air mixture at all, or b) as ozywalker suggested your turbo has sh*t itself If you haven't already, remove the intake elbow from your turbo and see what you can see if it's clean then I'm guessing you'll need to brace yourself for some pocket hurting turbo repairs/replacement Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680796 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 2m 6d Posted 05/04/19 05:49 AM Share Posted 05/04/19 05:49 AM Or blow by from broken ring lands Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680797 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,525 Member For: 17y 1m 22d Gender: Male Location: Melbourne Posted 05/04/19 11:26 AM Share Posted 05/04/19 11:26 AM or broken valve stem seals Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680831 Share on other sites More sharing options...
XR6T 520RWKW Member 40 Member For: 6y 3m 6d Posted 05/04/19 11:41 AM Author Share Posted 05/04/19 11:41 AM (edited) 6 hours ago, camo86T said: Ah, steam You've asked this question already, correct? As already said in one of the other threads, 'some' oil vapoyour from a vented catch can will be normal, IIRC your motor Is built so there will be more blowby than a stock motor. However; 'a lot' of oil vapour means a lot of oil coming from somewhere, either a) your catch can is sh*t and isn't separating the oil/air mixture at all, or b) as ozywalker suggested your turbo has sh*t itself If you haven't already, remove the intake elbow from your turbo and see what you can see if it's clean then I'm guessing you'll need to brace yourself for some pocket hurting turbo repairs/replacement I did ask this once. at that time my catch can was breathing which I wasn't sure if vapor is suppose to come out of it or not. as y might know this thing is my first turbo car. now I know, little bit of vapor is fine from catch can but the fact that I can see steam blowing out from engine inlet when took off the cap is worrying me. I don't understand if my turbo is fked, how is this related to engine. turbo and engine is separate and when engine (car) is parked I can see steam blowing out but how this has to do with turbo. Edited 05/04/19 11:51 AM by k31th fixed pic Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680833 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m Gender: Male Location: Western Sydney Posted 05/04/19 09:31 PM Share Posted 05/04/19 09:31 PM Use Google ya flucking turkey.It's normal.Stop filling the forum with jibber and use the sites bloody search function. Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680842 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 3d Gender: Not Telling Posted 05/04/19 09:49 PM Share Posted 05/04/19 09:49 PM 10 hours ago, XR6T 520RWKW said: when engine (car) is parked I can see steam blowing out Blowby under load is normal. Excessive blowby at idle is not and it shouldn't be smokey if there is any. I'd start with a compression test and take it from there. Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680843 Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,813 Member For: 15y 8m 19d Gender: Female Location: SA Posted 05/04/19 10:51 PM Share Posted 05/04/19 10:51 PM It hurts reading his posts.... like it sends my brain into hibernation. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94707-fg-turbo-engine-breath-heavy/#findComment-1680845 Share on other sites More sharing options...
